Dynamic Green Products Inc.
Author Topic: Wild Walnut Saplings - What is biggest i should try to move?  (Read 2124 times)
Offline reelman65
« on: September 21, 2017, 10:20:14 AM »
I have a part of my property that has a pretty old Walnut tree on it. We call her mama walnut. for several acres around her there are saplings of all sizes, from 1 year old up to 6-8" dbh. I would like to move some of them to more desirable location and cull whatever others need it, and leave the healthy ones. What is the biggest I should try to move? I would rent an excavator if that would allow me to move a bigger tree. I have heard the formula of 9 inch radius root ball for every inch of stem diameter. Thanks!!
75 Acres of hardwoods that i want to try to optimize for HW growth, health and habitat. Also interested in creating a few small stands of fruit/nut trees and sample of different native species
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
Re: Wild Walnut Saplings - What is biggest i should try to move?
« Reply #1 on: September 21, 2017, 11:08:15 AM »
Walnut has a pretty strong taproot.  Have you thought about just planting the nuts where you want them?
In the long run, you make your own luck good, bad, or indifferent. Loretta Lynn
Offline reelman65
« Reply #2 on: September 21, 2017, 12:51:59 PM »
Well i guess that would be a last resort, but if i can move a 5 yr old, then i'm 5 years ahead. I will need to cut hundreds of saplings anyway, just trying to do the optimal thing.
I will try to add a photo
Offline reelman65
« Reply #3 on: September 21, 2017, 01:01:42 PM »
Offline mike_belben
  • Pulp Friction
« Reply #4 on: September 22, 2017, 08:54:22 AM »
A 4 post tree spade on a tracked skid steer is the better tool, see if you can rent one of those.  They dig up all of those no problem.  The more you do, the more will survive.
Revelation 3:20
Offline reelman65
« Reply #5 on: September 22, 2017, 08:18:46 PM »
Good idea, thanks.
I suppose early spring or late winter is best time?
Offline PA_Walnut
« Reply #6 on: September 22, 2017, 08:53:20 PM »
I'm very interested in this thread. I need to do the same...I have had to take some huge walnuts on my land, and would like to replant for the next generation.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline nativewolf
« Reply #7 on: September 22, 2017, 09:25:12 PM »
If you dig with a tree spade you have to fill the hole back in with quite a bit of soil, fyi.  Otherwise you're destroying your site.
Walnut seedlings are cheap, 1000 are only few hundred dollars, survival will be better and they are easier to move.  For a few bucks you can plant 3-4 acres.  Just an idea.
We like to replant at a 10:1 ratio with Walnut.
Liking Walnut
Offline nativewolf
« Reply #8 on: September 22, 2017, 09:27:00 PM »
We also like to mix walnut and WO and Sycamore so that there is some diversity, the sycamore push the WO and Walnut to close canopy and grow taller faster.
In hardwoods, well they like fertilizer so if you have horses it is a great place for stable cleanings.  Especially horses getting wormed that you dont' want in the compost pile.
Liking Walnut
Offline mike_belben
  • Pulp Friction
« Reply #9 on: September 22, 2017, 09:41:09 PM »
Does walnut coppice very well?  I wonder how successful an operation youd have of getting coppice sprouts to root if taken from coppiced stump cuttings.. Does rooting hormone work on tree seedlings like it does on plant cuttings.
If it coppiced, just cutting some of those would produce a multitude more sprouts the next season for free.
It is a good point on soil disturbance.  Once you get past the topsoil and all the way down into the clay, nothing really grows but a few grasses out here.  Takes a long time to grass in an ugly log landing if too much top soil washes out.
Revelation 3:20
Offline TKehl
    • Kehlhof Ranch
« Reply #10 on: September 23, 2017, 08:38:28 AM »
The few young ones I've cut have coppiced somewhat.  Not vigorous like a locust or elm, but there are stump spouts.  Have not seen root/water sprouts.
I think this will boil down to economics.  Will the rental of the spade and labor cost less than the value of 5 years of walnut growth?
In my mind, I think I'd take a shovel to move the very small sprouts, then thin the rest as little as possible keeping the ones with the best form.
I'll be planting some walnuts (seeds) this fall on a piece of bottom ground too rocky and flood prone to crop.  Dad and I have meant to do it for years.  Went back to check it out and there is some natural regen walnut there that has come up since we brush hogged last.  Guess the site is good.   ;D
Offline nativewolf
« Reply #11 on: September 23, 2017, 08:58:51 AM »
I think that's about the right idea.  Besides, you don't save 5 years when you move large saplings.  They typically pull back a year, buy 1 year seedlings and you're only 3 years off on a 50 year rotation.   Walnut in dense groves needs thinning.  Might be painful but they need it, a good scientific hardwood forestry practices analogy is the teak thinning thread.  He's constantly cutting out the less desirable trees.  He's just doing it on a timeframe that  is a bit accelerated but I think it is a good example though.  You want crowns to barely be touching, form to be good, etc.  Just keep taking the bad ones out.  You can peel the bark and use in furniture, fence posts, firewood, etc.  Your goal should be a stand which much lower density than the average pine stand.
So in that picture, you really only need a few walnuts in 30 years.  How you get from that dense stand of young walnut to 30 years from now is going to tell you how valuable they are.  You'll be cutting the heck out of it over the next 10 years if you want to develop good boles.
Liking Walnut
Offline VirginiaFarm
« Reply #12 on: September 23, 2017, 10:35:18 AM »
I agree with nativewolf. What is your objective in moving them to a more desirable location? It would be interesting to work with what you have, thinning out the crooked ones and promoting growth in that stand of walnuts. Since you are located in Tennessee, you could also pick up income from selling the nuts.
Offline reelman65
« Reply #13 on: September 23, 2017, 09:20:27 PM »
I am definitely working with what i have there. but i have some other places on the property that i would like to have walnut trees. seems like a no brainer to move the trees that i would cull anyway to the new location, but it sounds like that may not be the case.
Offline PA_Walnut
« Reply #14 on: September 23, 2017, 09:33:40 PM »
I think I'll just purchase some seedlings as suggested. Is this the right time to plant?
How far apart should they be?
Northland 800 Kiln
Offline Hobnob2
  • I hope I get to work in the woods today!
« Reply #15 on: October 09, 2017, 04:45:35 PM »
Good advice on the thinning options so far. Keep in mind, though, that Walnut will tend to develop epicormic branches if opened up to too much light all at once. Dormant buds under the bark will respond to the new light and heat, pushing out new branches which can ruin your log grade.
This response is somewhat controlled by genetics but you can't tell ahead of time how your trees will respond so light thinning conducted often is the best way to keep some shade on those boles during the growing season and hopefully avoid the new branching in your beautiful lumber. In mixed stands I've even left non-walnut "shade trees" to the southeast, south, and/or southwest of each walnut tree I wanted to grow long-term, if the opportunity presented itself. Good luck!
Grow the best wood, faster, on the best trees.
Offline ohiowoodchuck
« Reply #16 on: October 23, 2017, 10:54:56 PM »
Where's a good place to get seedlings.
Education is the best defense against the media.
Offline John Mc
« Reply #17 on: October 23, 2017, 11:25:35 PM »
Transplanting is a huge stressor on a tree. The bigger the tree, the more it is stressed by being relocated. You are better off moving a younger smaller tree. Given a few years, a half inch diameter sapling will often overtake a tree several years older if both were transplanted at the same time.
The good news with Walnut: On a good site, they can grow incredibly fast. I cut down a walnut for my in-laws. It was almost 18" DBH, and only 17 or 18 years old.
Offline TKehl
    • Kehlhof Ranch
« Reply #18 on: October 24, 2017, 07:44:16 AM »
Planting the walnut nuts works real well.  They usually only cost the time to pick them up.  I'll be doing a few acres this way from trees selected for good form, growth, and small nut harvest.
If you want seedlings, check to see if you have a state tree nursery.  Missouri does and it ends up being about $30/hundred.
« Reply #19 on: October 28, 2017, 04:12:22 PM »
I got some in my front yard here in Ohio. The more I look into it, I don't think the soil is that good for them where I'm at.
black walnut saplings
Started by ktowne030311 on Tree, Plant and Wood I.D.
Last post April 17, 2015, 07:07:10 PM
by SwampDonkey
The biggest Black Walnut in the county.
Started by 123maxbars on Sawmills and Milling
Last post January 30, 2016, 12:37:22 PM
by 123maxbars
Maple saplings
Started by Ridge235 on Ask The Forester
Last post January 23, 2017, 10:08:26 PM
by Ridge235
My newest saplings
Started by Elevendy on Tree, Plant and Wood I.D.
Last post November 29, 2008, 02:40:47 PM
by RynSmith
