Woodmizer guide arm shield breaking
Started by irvi00, December 07, 2017, 06:41:14 PM
irvi00
Anyone else experience this? This is the shield that is attached to both ends of the movable guide arm. It cups under to shield the blade on the idle side. The factory weld broke and has been welded back twice. I'm ready to cut the shield off.
Ga Mtn Man
Yep, been there.  You've got to make sure you get a good weld fillet on the back side of the bracket to keep it from vibrating.
irvi00
My guy did that last time. But I could tell the shake was going to take it out again. Gonna cut that sucker off tommorow and not worry with it anymore. Just glad to know I wasnt the only one to see it.
drobertson
Can't say I've seen it,, seen more than my share of vibration issues, but not that one.  My best guess is the material, higher carbon,  welded and then it cracks.  Lots of components for all kinds of machinery are made of recycled materials. If these are not QC'd, during the billeting  process, well, this is what you might get, high carbon steel has strength, but if not handled properly it can become very brittle. Just a guess, my suggestion would be to pull it off, heat it to a low cherry, then weld it back then, either pack it in sand or draw it back in the oven at 400°  might as well throw a tater in while your are working on it,  ;D
Peter Drouin
Cut mine off, Good now. :D :D :D
Then some of the tin shields cracked too they're gone. :D ;)
A&P saw Mill LLC.
License NH softwood grader.
Chuck White
My mill had the blade guide shield "off"  (due to a mod) when I bought the mill, and I had it welded back on, no issues since!   ;)
POSTON WIDEHEAD
Quote from: Peter Drouin on December 07, 2017, 08:28:34 PM
What have you got left? 2 tires and a blade?  :D :D :D
irvi00
Its history tommorrow morning. I grew up walking around a 0frick and miner edger without gaurds. Made it this long, I figure one less shield wont hurt. I still use that old miner.
Peter Drouin
almost Mr goat, :D :D
A&P saw Mill LLC.
irvi00
Kbeitz
You need a counter weight to take up the harmonics of the vibrations.
Love machine shop work
and Wood work shop work
And now a saw mill work
petefrom bearswamp
Most of my mills tin is stored in my pole barn
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Jim_Rogers
You might consider solving the vibration issue.
Jim Rogers
Peter Drouin
Quote from: Kbeitz on December 08, 2017, 08:18:02 AM
Where would you hang that? :D :D :D :D :D
A&P saw Mill LLC.
irvi00
Dave Shepard
I Haven't had to remove anything but the flapper on the muffler, so far. DanG thing would rattle at idle and drive me crazy.
Kbeitz
Quote from: Peter Drouin on December 08, 2017, 07:27:16 PM
I would start with a strong magnet.
Just stick it on and watch your vibrations.
Move it around to find the magic spot.
I do this with my boring bar on my metal lathe to stop chatter.
Interesting ...
http://www.physicsclassroom.com/class/sound/Lesson-4/Fundamental-Frequency-and-Harmonics
Quote from: Jim_Rogers on December 08, 2017, 03:22:51 PM
Jim Rogers
I too am wondering why it is vibrating and where it is coming from?  Are you running Wood-Mizer B57 belts?
ladylake
Seems like most engines vibrate plenty at idle, not so bad when cutting.  Steve
isawlogs
 Have had to weld mine also a few times. Don't worry about it, keep sawing. If you're not sawing you sure aren't breakin' anything.  ;D ;D
   Marcel
terrifictimbersllc
My blade covers make a lot of  noise when idling.
irvi00
Its a lt50 electric. I dont really experience any vibration while sawing. The shield in question is quite heavy to only be attached in two very small points. No mill will be perfectly vibration free. But as I said earlier, the problem is solved.
POSTON WIDEHEAD
I get very little vibration when sawing or when idling.
Most of the vibrating concussion comes when I turn a big cant.
A mill wood probably have more vibration damage if it sets on a concrete slab I would thing.
Peter Drouin
How can you tell, your mill doesn't run much Mr goat?  :D :D :D
A&P saw Mill LLC.
POSTON WIDEHEAD
Quote from: Peter Drouin on December 09, 2017, 07:07:37 PM
......and no broken welds.  :D :D :D :D
