Woo-hoo 2017!
Started by terrifictimbersllc, December 28, 2017, 07:46:54 PM
terrifictimbersllc
My Saturday customer just cancelled, thinks too much snow is coming.  That's it for 2017 sawing for me.   Going to sit by the fire a bit now.  8) 8)
143400 BF on my WM this year.
nativewolf
Very nice.  A seat by the fire when it is 10 degrees is a fine idea.  Best of luck in 2018
Liking Walnut
petefrom bearswamp
Havent sawed in 6 weeks now and dont intend to unless we get a protracted January thaw.
Did sell a couple of hundred bucks worth of Ash and Butternut lumber tho 3 days ago.
Only 5 inches of snow here
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Crossroads
Quote from: terrifictimbersllc on December 28, 2017, 07:46:54 PM
Just curious, do you work by the bdft or buy the hour and just keep track of your footage? I work by the hr or bdft depending on the job, but I rarely keep track of the footage when working by the hour.  My Saturday customer canceled too and rescheduled for 1/8
terrifictimbersllc
By the hour but keep track of the bf, either log scale or actual.
I would advise anyone new to sawing esp. in business to keep a log of the following for every job.  There's a lot of uses one can make of this information.
date
customer
engine hr start
engine hr finish
board feet either sawn or log scale
Also track fuel (gallons) purchased for/used by mill, not for every job but all the purchases.   You'll have this anyway if you fill out form 4136 federal fuels tax credit but the gallons might not be easy to pull up later unless you go to that form.
Crossroads
Thanks for the info, 2018 just might be a good year to start keeping a log like that.
Chuck White
Quote from: terrifictimbersllc on December 29, 2017, 01:06:59 PM
date
customer
engine hr start
engine hr finish
This info is also useful for Wood-Mizers "100,000 bf & One Million bf clubs"
Also keep track of the number of blades you go through!
alanh
nice work tt, my number would have the comma way more to the left.....
WV Sawmiller
    I have kept a log (Excel spreadsheet) ever since I got my mill. I capture the number of logs sawed, bf, bf/hr, type wood and comments (thicknesses, special cuts, etc) every day. I keep the log by year and make notes of starting hours on my mill and total sawed to date at the start of each year so I can keep up with totals and compare changes in cutting rates.
   For what its worth I find I have been cutting a little over 151 bf/hour when comparing operating hours to total. I see I cut about 142 bf/hr the previous years and 176 bf/hr this year so experience is paying off.
