Hey Gene!
Started by scsmith42, December 31, 2017, 11:03:40 AM
scsmith42
Will this advice be in the next revision of "Drying Hardwood Lumber"?
LOL!
Scott
"Both Lignomat and Delmhorst have nearly identical packages, techniques and equipment for measuring da MC in da kiln.  Appreciate dat in-kiln measurements are not too accurate above 30% MC, and yet almost all quality is controlled by da kiln conditions above 30% MC.
When running a kiln, us guys usually figure dat 3 samples are not enough...yoozguys might have 100 pieces of lumber in a small kiln ta 10,000 in a larger kiln, so knowing da MC of just 3 pieces is not reliable enough.  dat is why around 12 measurements initially are desired ta find da wettest MC (using knowledge ta choose da 12 samples) as well as da driest MC.  Once us guys find da two wettest and one driest, us guys can certainly use three samples ta get our daily readings ta run da kiln, but us guys might measure da udder nine samples from time ta time also.
How long should yer wires be ta reach from a sample inside da kiln ta where yer moisture equipment is set-up?  Are da 12' cables long enough?  da best readings will occur when da meter is used at room temperature and is stored at dat level too.
I have clients dat have used deez systems.  They and I really like da wireless systems, which means no cables are required, but they are expensive.  da simply system in yer link has been used too.
Most clients will use separate measurements at da end of drying ta confirm da final MC values; da inserted pins can be several percent off.  So, yoozguys do need their "hammer probe" shown as an "add" and also da case for da meter.
Note da non-USA made meters almost always are not too accurate, but such inaccurate meters have fairly low prices and are difficult ta have repaired.
As yoozguys are a lot closer ta New Jersey, if yoozguys need repairs, yoozguys should check da Delmhorst system too.  In some ways, dis is like comparing Ford versus Chevy...both are good and have many devoted followers.
One last comment...If yoozguys have clients dat use one brand ta check da MC on Lumber yoozguys sell, yoozguys probably should have da same brand dat they use.  There are differences in moisture readings from different brands when used on da same piece of wood.  Some brands calibrate using da published resistance values for wood and udder brands use actual testing of many samples."
Tom's 3638D Baker band mill
50 Acre Jim
Someone help me, I'm loosing my mind!    Are you typing "yoozguys", "dat", "da" and "ta" or has something captured my browser and I'm the only one that sees it???
Quote from: scsmith42 on December 31, 2017, 11:03:40 AM
LOL!
Scott
Go to work?  Probably Knott.  Because I cant.
Grizzly
Jim, the explanation is in another thread. Jeff got creative in celebrating Yooper night or something. Yooper stuff for sure.
Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
50 Acre Jim
Quote from: Grizzly on December 31, 2017, 11:56:59 AM
OK, got it!
scsmith42
Lol.  Jim, you should have been around the first time that Jeff did it.  All of the chainsaw guys went nuts!  I still laugh when I think about it.
Scott
The chainsaw guys are all nuts anyway  :D.
customsawyer
I notice you guys are talking about them in a section they probably don't go to.  :D
www.thecustomsawyer.com
Peter Drouin
Quote from: customsawyer on January 01, 2018, 08:00:27 PM
I was thinking the same thing, :D :D :D :D Hi customsawyer and  :new_year:
A&P saw Mill LLC.
License NH softwood grader.
4x4American
...sooo...the computer does it err?   ???
Boy, back in my day..
Andries
No err 4x4
If you're from the UP , the computer is finally doing the correct "spell check".
:D
LT40G25
Ford 545D loader
Stihl chainsaws
customsawyer
Hey Peter and everyone else. I'm not trying to ignore anyone just busy beyond belief. Hope everyone is well.
