Dynamic Green Products Inc.
Author Topic: TDC marks on a 24 hp. Onan  (Read 1166 times)
Offline joman
« on: January 27, 2018, 03:18:07 PM »
Does any one know exactly where these are located?
89 Woodmizer LT40HD
Morgan LittleChamp Edger
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: TDC marks on a 24 hp. Onan
« Reply #1 on: January 27, 2018, 03:53:26 PM »
The timing marks, should be visible on the front gear cover, (under the blower housing) it should show, 2 major marks, 25 degrees and 20 degrees plus 1 degree lines in between. Those marks/lines should line up to a timing mark on the flywheel itself. (If you rotate the flywheel slowly, you should see a long harsh mark on the flywheel)
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline joman
« Reply #2 on: January 27, 2018, 06:20:10 PM »
If I remove the hose that goes to carburetor filter housing and look down thru the hole at the fly wheel should I be able to see it or should I remove alt. Belt and pully then remove shroud over flywheel to see it in order to find Tdc to check valve adjustment?
89 Woodmizer LT40HD
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
« Reply #3 on: January 29, 2018, 03:37:09 PM »
Here's what I found in the Onan service manual.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Offline joman
« Reply #4 on: January 30, 2018, 09:22:18 AM »
I found the Tdc mark on the fly wheel and adjusted the valves. Hopefully I did it correctly. The intake valves were good at .005 but the exhaust valves were to tight had to readjust them to .013
89 Woodmizer LT40HD
Offline Kbeitz
    • My Hobbies
« Reply #5 on: January 30, 2018, 12:00:11 PM »
They will even get tighter after the engine warms up.
I hope it's working good now.
Offline joman
« Reply #6 on: February 03, 2018, 06:14:19 AM »
   After adjusting the valves I put on a new carburetor and cleaned the breather valve. The engine started right up and seems to be running pretty good without any smoke.
89 Woodmizer LT40HD
Saw marks from a bandmill.
Started by Kansas on Sawmills and Milling
Last post February 24, 2013, 08:02:49 AM
by Magicman
log grade marks
Started by minesmoria on Ask The Forester
Last post January 03, 2006, 08:41:22 PM
by Pullinchips
Sighting Marks
Started by twistedtree on Chainsaws
Last post November 25, 2005, 11:54:51 PM
by fishhuntcutwood
marks on lumber
Started by woeboy on Sawmills and Milling
Last post June 17, 2010, 06:19:33 AM
by terrifictimbersllc
