Bent broke woodmizer
Started by pineywoods, February 04, 2018, 07:32:59 PM
pineywoods
This mill just brought to my shop for repairs. Yes, that wheel is bent over about 20 degrees.
The spindle is bent, the idler bandwheel cover is badly bent. I suspect the guide positioning mechanism is trashed. Hope the head frame is not bent. Hydraulic control valves, handles all broke and bent, valves trashed ? Mill was parked by side of the road, got T-boned by a truck. shoved the mill sideways 6-8 feet. No, it's not my mill, belongs to a local sawyer. It has about 8000 hours on the clock, 2500 on a new kohler 25 hp. Should be worth fixing..
fishpharmer
Pineywoods, if anyone can repair it, you can.  Will the truck driver's insurance pay for damages?
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Southside
Can you post a picture of it pineywoods?  For some reason the theme music to the Million Dollar Man is coming to mind - "Gentlemen we can rebuild him - we have the technology..."
White Oak Meadows
pineywoods
Pic posted on the original thread. I'll post pics of the progress. Gonna be a while, I'm down for couple of weeks with shoulder surgery. The damage was done at night, we have some ideas but no proof. I'm quite familiar with this particular mill. It has lead a hard life..rode hard and put away wet, so no telling what else will need fixing. I flatly refused to paint it  ;D
POSTON WIDEHEAD
Take a truck and T-bone it from the other side. Charge him $300 and send him home.  :D :D :D
Southside
Well not that's really odd - the photo was not there the first time.
Would someone PLEASE go to the WM dealer in South Carolina and let the goat get his new mill already!!!  He is getting some rambunctious!!!
White Oak Meadows
petefrom bearswamp
Looks like a time consuming project Piney
But Im sure u are up to it.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Darrel
This will be both an educational and entertaining thread so I'm staying tuned.
1992 LT40HD
Resonator
I would go over the parts and labor estimate carefully, and see if its worth it. At 8000 hours you may end up rebuilding the whole machine. Money wise it may make more sense to cut your loses and find another good used LT40 with fewer hours. My two pennies.
pineywoods
Well, it took a while, but I delivered the repaired mill today. Lots of bent, broke, and missing parts. Had to fab some parts, mostly covers that hired hands had removed and thrown in the sawdust pile, never to be seen again. OK, so I can't match paint very well, it's as close as I could find in a rattle can. The brightly colored bandwheel covers were formerly the sides of a discarded washing machine, carved out with my new plasma cutter. During all this work, the owner passed away, and now I am dealing with an estate..Should work out ok, the estate administrator is a good friend.
Darrel
Looks good piney. That's a manual LT40, they don't make those anymore. I don't know if that makes it more valuable or not.
1992 LT40HD
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
kelLOGg
Quote from: Peter Drouin on July 14, 2018, 06:11:44 AM
Nice job. smiley_thumbsup AND you did it after shoulder surgery - that's amazing. Piney just doesn't slow down.
MartyParsons
QuoteThat's a manual LT40, they don't make those anymore.
Yes you can still order a LT40 manual mill. Not much call for these but they are still available.
M
pineywoods
The major item was the bent axle. The idle side wheel took most of the hit, axle bent about 20 degrees. I elected to not try to straighten it, not much way to get it right with removing the axle. will just replace with a boat trailer axle at a later time. The mill will be a fixed setup anyway. The idle side bandwheel enclosure was badly mangled. That sheet metal is TOUGH.  roller guide mechanism was bent a good bit Lots of big hammer, crowbars, etc. I cut a log into 2x2 to check everything out. Straight smooth cuts, everything tracked nicely. This mill has a copy of my pineywoods hydraulics, some minor leaks and bent contols, probably not related to the collision..fixed all that..
POSTON WIDEHEAD
Piney, I think you did a really great job!  8)
