Bugs: worries after air drying?
Started by Erik A, March 01, 2021, 01:48:12 AM
Erik A
I have read about PPB's eating dry wood and carpenter bees, obviously could run into termites if lumber touches the dirt!
So... any heads up or references for other bugs that will continue being a threat after the lumber is air dried?
I thought I read that grubs dont like wood after the MC drops down.
I dont have a kiln to kill the buggers, have read a bit about chemicals to paint on the boards.
Just read PPB's attack hard wood not soft wood (Pine) ??
Some pine boards - going to do some semi-rustic signs with the origin so dont care about the bug holes (just the bugs if there are any)
I did notice some limbs we cut (dogwood? or non-fruit mulberry?) and it looks like something was (is) boring in the limbs and leaves behind something that fills the tunnel it made? I will see if I can get a picture if they did not get burnt!
Just trying to figure on how many bugs may be brought inside (mostly pine boards) without a kiln to cook them?
Ref:
PPBs 20-05 https://forestryforum.com/board/index.php?topic=110601.0
       05-09 https://forestryforum.com/board/index.php?topic=14038.0 Ohio link is broken
Pine Beatles 20-11 https://forestryforum.com/board/index.php?topic=112817.0
                 17-09 https://forestryforum.com/board/index.php?topic=97705.0
Bugs in White Pine 16-08 https://forestryforum.com/board/index.php?topic=92000.0
Soap solution on pine 14-10 https://forestryforum.com/board/index.php?topic=78489.0
Keeping bugs out of Ponderosa Pine Logs 21-01 https://forestryforum.com/board/index.php?topic=113742.0
Bugs is bugs 20-03 https://forestryforum.com/board/index.php?topic=110567.0
Bugs https://forestryforum.com/board/index.php?topic=95930.0
Drying buggy wood 12-06  https://forestryforum.com/board/index.php?topic=58972.0
Boron 20-08 https://forestryforum.com/board/index.php?topic=111948.0
Keeping bugs out of your lumber 06-03 https://forestryforum.com/board/index.php?topic=17821.0
Old logs and termites 19-10 https://forestryforum.com/board/index.php?topic=108053.0
Spraying Boards with Borax 20-09 https://forestryforum.com/board/index.php?topic=112237.0
kantuckid
Good luck keeping carpenter bees out of pine or poplar. Other than spraying and crossing my fingers and eyes, my traps have worked the best. Yes, I have tried every spray used commercially, plugged the larvae holes, etc., but they are one nasty critter. I've read that poplar & cedar are their natural homes in the woods. My traps are made from cedar 3x3 scraps with a top board for mounting. main problem I've had is rusty canning jar rings & lids used to hold pint jars full of bee corpses. Maybe  should have gone with water btl design traps but I just didn't want the plastic bottles hanging from my eaves!
Why do we have them now is a question I've had?  I have a small stack of EWP beams dead stacked under a roof and they have been loving it for ~ 15 years since stacked. hopefully I'll have enough left to use for porch rafters on my small cabin build.
Walmart has a Chinese bee trap selling for $17.95! Made from plastic and a corpse storage thingy. It's a war folks.
YellowHammer
Air dried or kiln dried wood is the perfect meal for some of the more nasty and insidious insects.  There is no residual protection in dried wood, it is an open Happy Meal for anything that wants to move in.  You can spray with Timbor or Boracare and that will help protect by putting up a barrier on the wood surface, but won't kill the bugs inside.  However, it is much better than doing nothing.
Mulberry, persimmon and such are a sweet wood and are very prone to insect infestation.
I get call maybe once a month or two from people who build inside or build furniture with non sterilized wood and have "weird" bugs flying around in their house and ask what they can do about it.  I always tell them the same thing "call an exterminator."
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
alan gage
I air dried some ash and then milled it into flooring for my house. Had some borers hatch out of it a month or two later. Didn't bother me but a customer probably wouldn't have been so happy (nor a wife if there was one). The cat was pretty entertained by it.
Was air drying some honey locsut slabs with bark on. They were down to about 16% when I peeled the bark off and found plenty of happy little grubs. I'm sure they were there when the log was sawn.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
farmfromkansas
You need to read up on the "solubor" threads.  Right after you saw your boards, roll a mix of solubor on it, all 6 surfaces, before you stack and dry it.
Trackerbuddy
bora-care kills active infestations and prevents bugs. I've had success with it in the past.
You can buy it ready made or
There are recipes floating around the web.  It's ethylene glycol, boric acid and borax.  After cooking it becomes hydroscopic.  The solution seeks water in the wood carrying the borate with it. When insects eat the wood they die.  It's best sprayed on wood that is green before air drying it. The borate penetrates deeper that way.
It stays in the wood permanently and does not effect future working properties or finishes
