Band mill Router Plane
Started by Kbeitz, January 25, 2018, 01:09:09 PM
justallan1
Very cool. Are you going to make it hand powered or have motors on it's movements?
What do you figure the RPMs are going to be?
Nice work.
Ljohnsaw
K,
Looking good!  Sounding good, too.
What is the HP on that motor?  For the bit you are planning on spinning, I think you would want at least a 1hp - 2hp would be better. +1 on what speed will you be spinning that?  If that is a 3750 motor and your pulley set up looks like its doubling, you are at the bottom end of what I think you should spin it for a good smooth finish.
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Kbeitz
Quote from: justallan1 on February 15, 2018, 09:54:32 PM
Nice work.
I'm thinking to power one of the movements . The short one.
Love machine shop work
and Wood work shop work
And now a saw mill work
Kbeitz
Quote from: ljohnsaw on February 16, 2018, 12:16:19 AM
K,
One Hp 3400 rpm.  I want to use the insert bits later but I'm going to try what
I have first. The pulley on the motor is adjustable for speeds and the one on
the arbor is a step pulley. I will play with them both.
xlogger
On your first post on the last picture where did you get those rollers at?
Kbeitz
Quote from: xlogger on February 16, 2018, 06:46:51 AM
The little rollers on the top of the machine came from the junkyard.
The bottom ones I got from E-bay.
Kbeitz
I really dislike sheet metal work.
Kbeitz
Did I say how much I hate sheet metal work... It took me all day to get this
much done but the hard part is finished.
Bruno of NH
X 2 on what Peter said you can make a lot of things  :)
Kbeitz
The chain cover is finally done. 14ga galvanized steel.
Kbeitz
I got my pull along handles mounted on both sides. Next I need to put a handle on the molding head or make it power feed. I'll sleep on it a few days.
Ljohnsaw
For a better feedback when working, I'm thinking a simple hand crank with some clothesline rope would be easy and effective.  Just use a large enough capstan (2"?) so you can turn the handle fairly slow.
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Kbeitz
Quote from: ljohnsaw on February 17, 2018, 03:07:21 PM
The reason I was thinking of some kind of motorized movement was so that part of the machine would stay where I put it while I'm moving the other part. Right now everything just moves way to easy. I was thinking about two sprockets and a chain and a special master link follower that would move the whole thing back and forth on it's own.
Kbeitz
I slept on it last night and came up with this. Another DC variable speed motor mounted right on the moving head. I will run a strand of roller chain like the saw mills have for the motor to follow on. Easy fix.
Kbeitz
I got the side motor mounted today. Tomorrow will be the chain and sprocket. While in church today dreaming about this project I dreamed up the idea of running a hitch to my mill carriage so the carriage will push it down the track. Hands free operation. With my mill remote I wont have to touch it. Just sit back and watch.
Kbeitz
About all I have left to do it to wire up this motor and paint.
Crusarius
I am very anxious to see this work.
Kbeitz
Ljohnsaw
Quote from: Kbeitz on February 19, 2018, 06:07:39 PMAbout all I have left to do it to wire up this motor and paint.
And some limit switches on the travel motor?
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
justallan1
Quote from: ljohnsaw on February 19, 2018, 10:31:53 PM
I was thinking you should use limit switches to have it automatically change directions, of course after a pause and 1" advance. 8)
Kbeitz
limit switches will be added... Maybe later a PLC. I'm worried the PLC wont like it outside.
I already have limit switches on the up and down but not on the side movement yet.
The top speed of the side motor is only 4rpm and I'm putting a controller on it to go even slower. For now I'm just going to use a jog switch.
Kbeitz
Something happened to my computer. When typing my post the font size is so small I cant hardly read it but when I post it it come out larger than normal. Is this problem on my side?
starmac
I don't know, but your last post was back to normal.
Kbeitz
Quote from: starmac on February 20, 2018, 02:25:42 AM
I seen that but it was anything but normal when I was typing it. As this one the font is so small...
Crusarius
if you hold ctrl key and roll the scroll wheel on the mouse that will change your font size that you see.
