Help... trying to bring her back to life.
Started by djp, October 12, 2020, 11:43:57 AM
djp
Long story short... unidentified Frankenstein mill that I need some help with. I'm learning about this stuff as I go so please excuse my lack of knowledge and jargon. I've been reading a lot on here and found it invaluable so thank you all for your help.
What I know... the power plant is a 1941 International Harvester BD264. We've got it in tip top shape now...
The mill has one gear stamped w/ Corley T-102 but otherwise has nothing on the carriage/knees/anywhere else I can find so Corley says it's not theirs.
Looks to me like an old mill that would have been on a wood frame, later adapted to a steel frame... made from at least one Corley part and then nothing else Corley...
#1, Would love to try and identify the mfg. if only for curiosity's sake.
#2, Need the logdog? thing as my carriage only has one. Wondering if anyone has one sitting around (or has an interesting way to fab an alternative setup but would love to keep as original as possible.
#3, appreciate any do's and don'ts as it relates to not breaking the machine, myself, or anyone else when operating this thing...
Chuck White
Welcome to the Forestry Forum, djp!
Looks like quite a project you've got going there!
Nebraska
I don't know sickem about circle mills, but every time I see a thread like this, I catch  myself thinking "geez that's so cool". I may get to the point soon I need to go watch one for a while, but then I'm afraid of the progression of my  affliction. Plus there's one in a pile at a neighbor's three miles south of my house.... ;) Anyway good luck with your project..
djp
Get in, the water is great! It's a beautiful thing. Thanks for the well wishes.
Don P
Welcome to the forum.
When you get a chance get some closer and clearer pics of the husk, setworks and dog (you need at least 2) and hopefully someone will recognize some parts.
djp
Quote from: Don P on October 12, 2020, 10:50:26 PM
I've added a bunch of pics in my gallery... will try adding some here too. Thanks.
djp
Quote from: Chuck White on October 12, 2020, 03:07:43 PM
Thank you! Yes, it's coming along. I didn't take as many pictures as I should have but I'm trying to now.
djp
As you can see I managed to not take a single pic of the “getting to this point of the build”. I do have some videos that I will figure out how to load some frames and hopefully get some other pics from the fam. But here are some pics for the sake of trying to figure out who she is.
Note that the steel frames that hold the knee are stamped Jones&Laughlin which was a major steel producer from Pittsburgh. Thought that was cool.
Satamax
French CD4 sawmill. Mecalac digger, with grapple. Self moving hydraulic boom crane. And a Brimont TL80 CSA.
djp
Quote from: Satamax on October 14, 2020, 11:50:34 PM
DJP, a very good thread about a circular sawmill rebuild. Worth reading.
https://forestryforum.com/board/index.php?topic=58233.0
Thanks... Wow, a couple threads in and good lord that build is intense.
Fortunately, mine has been fairly easy as my setup was pumping out railroad ties up until 12 months ago... and only sat idle for the 8 months before I picked it up in June.
After a new water pump, welding the intake, some re-wiring, rebuilding the carb, changing a couple gaskets, and some functional mods we are pretty close to cutting. I estimate a couple weeks out but I’ve been saying that since July.
We basically have the engine ready and are now doing some safety mods and adjusting everything to get ready to cut the first board. Including hunting for that second rack/dog setup. I will post a series on the engine soon... very few pics unfortunately but I will try to show the progression.
Thanks for sharing.
Woodpecker52
Some mills have a board splitter at the end of frame to separate board after saw and prevent any curve back.
Walnut Beast
Don P
To my knowledge they all have splitters and it needs to be there, good way to see how far the mill can throw a log without it.
The bearing boxes usually have wool felt in them to let oil thru but not trash and it would be a good idea to make some covers for them, oil floats on water so open to the weather those bearings are going to be lubing on water in short order..
Looks like it'll be sawing soon!
djp
Quote from: Woodpecker52 on October 15, 2020, 12:20:36 AM
That sounds like a good idea. If anyone has pics I'd love to see how yours work. Also, I'm in the process of bolting on some stops at the end of the rail frames as a stop so that the carriage doesn't go flying. I will post some pics when I get back from a couple days at the in-laws.
djp
Quote from: Don P on October 15, 2020, 05:03:59 PM
The bearing boxes too. Makes sense. Eventually we plan on moving of the barns (that's currently under the power line) over
the mill... that should help too with the rain but I love the idea of a bearing box.
mike_belben
On your phone you can get stills from vid by pausing where you want, screenshotting, [usually 2 buttons at once takes a picture of your present screen] then crop/rotate as needed.  Use any free JPG convertor app to make it a JPG then upload that image to your gallery and put the < tag > style of link in your post.
Praise The Lord
Don P
You can see the bearing box cover in the top pic and the bottom of the wick sticking down thru the bearing shell in the lower shot.
That looks like it might be and American mill Heacock feed
moodnacreek
That arch at the setworks with link chain and sprockets is different. Is that a receder ?  Those babbit bearings and the mandrel setting outside, not good. Should be converted to roller bearing pillow blocks and perhaps new shaft.   Farm mechanic has posts on 'saw hammering' if you haven't seen it.  The mandrel, collars and bearings are everything on a sawmill. Has to be done a certain way and not cheap. Good luck, keep posting.
Gearbox
djp don't put a stop on the back of the track. At some point you are going to need to saw a long cant for something and are going to need to hang one axel of the carrage off the track . I have done it many times to saw a 20 ft 6x8 .
djp
Quote from: moodnacreek on October 16, 2020, 08:16:54 PM
Gonna have to walk me through that a little slower. I'm learning... Got back to the mill today and turns out while I was out of town my dad wasn't explaining to one of my brothers how the system works and that chain I think you are referencing snapped. Hunting that down now to replace.
moodnacreek
A receder is some type of mechanism to throw the head blocks back to load another log after the last board has been taken off. Without this you have to jack them back by hand and that gets old.
Southside
Quote from: Nebraska on October 12, 2020, 05:19:56 PMI don't know sickem about circle mills, but every time I see a thread like this, I catch  myself thinking "geez that's so cool"
Funny - I consider myself to be rather adventurous, ya know got paid to jump from planes, rode a few bulls - that sort of foolishness, but every time I see one of these mills I catch myself thinking "geez that's gonna hurt".. :D
