Dynamic Green Products Inc.
Author Topic: Help... trying to bring her back to life.  (Read 1075 times)
Offline djp
« on: October 12, 2020, 11:43:57 AM »
Long story short... unidentified Frankenstein mill that I need some help with. Iím learning about this stuff as I go so please excuse my lack of knowledge and jargon. Iíve been reading a lot on here and found it invaluable so thank you all for your help.
What I know... the power plant is a 1941 International Harvester BD264. Weíve got it in tip top shape now...
The mill has one gear stamped w/ Corley T-102 but otherwise has nothing on the carriage/knees/anywhere else I can find so Corley says itís not theirs.
Looks to me like an old mill that would have been on a wood frame, later adapted to a steel frame... made from at least one Corley part and then nothing else Corley...
#1, Would love to try and identify the mfg. if only for curiosityís sake.
#2, Need the logdog? thing as my carriage only has one. Wondering if anyone has one sitting around (or has an interesting way to fab an alternative setup but would love to keep as original as possible.
#3, appreciate any doís and doníts as it relates to not breaking the machine, myself, or anyone else when operating this thing...
Offline Chuck White
  • Sawing Mobile since 2005
Re: Help... trying to bring her back to life.
« Reply #1 on: October 12, 2020, 03:07:43 PM »
Welcome to the Forestry Forum, djp!
Looks like quite a project you've got going there!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #2 on: October 12, 2020, 05:19:56 PM »
I don't know sickem about circle mills, but every time I see a thread like this, I catch  myself thinking "geez that's so cool". I may get to the point soon I need to go watch one for a while, but then I'm afraid of the progression of my  affliction. Plus there's one in a pile at a neighbor's three miles south of my house.... ;) Anyway good luck with your project..
Offline djp
« Reply #3 on: October 12, 2020, 09:46:23 PM »
Get in, the water is great! Itís a beautiful thing. Thanks for the well wishes.
Offline Don P
    • Calculator Index
« Reply #4 on: October 12, 2020, 10:50:26 PM »
Welcome to the forum.
When you get a chance get some closer and clearer pics of the husk, setworks and dog (you need at least 2) and hopefully someone will recognize some parts.
Offline djp
« Reply #5 on: October 14, 2020, 10:56:29 PM »
Iíve added a bunch of pics in my gallery... will try adding some here too. Thanks.
Offline djp
« Reply #6 on: October 14, 2020, 11:06:50 PM »
Thank you! Yes, itís coming along. I didnít take as many pictures as I should have but Iím trying to now.
Offline djp
Some pics...
« Reply #7 on: October 14, 2020, 11:39:27 PM »
As you can see I managed to not take a single pic of the “getting to this point of the build”. I do have some videos that I will figure out how to load some frames and hopefully get some other pics from the fam. But here are some pics for the sake of trying to figure out who she is.
Note that the steel frames that hold the knee are stamped Jones&Laughlin which was a major steel producer from Pittsburgh. Thought that was cool.
Offline Satamax
« Reply #8 on: October 14, 2020, 11:50:34 PM »
DJP, a very good thread about a circular sawmill rebuild. Worth reading.
https://forestryforum.com/board/index.php?topic=58233.0
Offline djp
« Reply #9 on: October 15, 2020, 12:12:56 AM »
Thanks... Wow, a couple threads in and good lord that build is intense.
Fortunately, mine has been fairly easy as my setup was pumping out railroad ties up until 12 months ago... and only sat idle for the 8 months before I picked it up in June.
After a new water pump, welding the intake, some re-wiring, rebuilding the carb, changing a couple gaskets, and some functional mods we are pretty close to cutting. I estimate a couple weeks out but I’ve been saying that since July.
We basically have the engine ready and are now doing some safety mods and adjusting everything to get ready to cut the first board. Including hunting for that second rack/dog setup. I will post a series on the engine soon... very few pics unfortunately but I will try to show the progression.
Thanks for sharing.
Offline Woodpecker52
« Reply #10 on: October 15, 2020, 12:20:36 AM »
Some mills have a board splitter at the end of frame to separate board after saw and prevent any curve back.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Walnut Beast
« Reply #11 on: October 15, 2020, 12:24:52 AM »
Pretty cool
Offline Don P
    • Calculator Index
« Reply #12 on: October 15, 2020, 05:03:59 PM »
To my knowledge they all have splitters and it needs to be there, good way to see how far the mill can throw a log without it.
The bearing boxes usually have wool felt in them to let oil thru but not trash and it would be a good idea to make some covers for them, oil floats on water so open to the weather those bearings are going to be lubing on water in short order..
Looks like it'll be sawing soon!
Offline djp
« Reply #13 on: October 16, 2020, 12:43:55 PM »
That sounds like a good idea. If anyone has pics Iíd love to see how yours work. Also, Iím in the process of bolting on some stops at the end of the rail frames as a stop so that the carriage doesnít go flying. I will post some pics when I get back from a couple days at the in-laws.
Offline djp
« Reply #14 on: October 16, 2020, 12:55:29 PM »
The bearing boxes too. Makes sense. Eventually we plan on moving of the barns (thatís currently under the power line) over
the mill... that should help too with the rain but I love the idea of a bearing box.
Offline mike_belben
  • Pulp Friction
« Reply #15 on: October 16, 2020, 01:11:41 PM »
On your phone you can get stills from vid by pausing where you want, screenshotting, [usually 2 buttons at once takes a picture of your present screen] then crop/rotate as needed.  Use any free JPG convertor app to make it a JPG then upload that image to your gallery and put the < tag > style of link in your post.
Revelation 3:20
Offline Don P
    • Calculator Index
« Reply #16 on: October 16, 2020, 08:14:50 PM »
You can see the bearing box cover in the top pic and the bottom of the wick sticking down thru the bearing shell in the lower shot.
That looks like it might be and American mill Heacock feed
Offline moodnacreek
  • Sawin by the notches
« Reply #17 on: October 16, 2020, 08:16:54 PM »
That arch at the setworks with link chain and sprockets is different. Is that a receder ?  Those babbit bearings and the mandrel setting outside, not good. Should be converted to roller bearing pillow blocks and perhaps new shaft.   Farm mechanic has posts on 'saw hammering' if you haven't seen it.  The mandrel, collars and bearings are everything on a sawmill. Has to be done a certain way and not cheap. Good luck, keep posting.
Offline Gearbox
« Reply #18 on: October 16, 2020, 09:56:35 PM »
djp don't put a stop on the back of the track. At some point you are going to need to saw a long cant for something and are going to need to hang one axel of the carrage off the track . I have done it many times to saw a 20 ft 6x8 .
My mill comes back to life
Started by MrMoo on Sawmills and Milling
Last post September 19, 2012, 01:27:31 PM
by MrMoo
Mighty Mite back to life
Started by cbailey1956 on Sawmills and Milling
Last post October 06, 2017, 09:38:23 PM
by dgdrls
Central Boiler 5648 stopped working, then came back to life - fuse?
Started by Keltydog on Firewood and Wood Heating
Last post April 23, 2019, 05:43:46 AM
by E Yoder
Bring it home.
Started by Peter Drouin on Firewood and Wood Heating
Last post February 12, 2017, 06:01:15 PM
by thecfarm
