Did something dumb today.
Quote from: btulloh on June 30, 2021, 08:28:35 PM
Did they really fix it or just pretend to fix it?  Hard to have confidence in the dealer under those circumstances.
Good question.  The recall simply involved checking the torque spec.  My guess is that once they got the truck they looked into the recall and realized it was easy to do.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Old Greenhorn
It always tweaked me the way dealerships would give no priority to the "E" vehicles. Our dealer used to leave our ambulances out in their lot for days at a time time in the winter, they refused to pull it in the shop overnight, freezing anything inside that would freeze, they never put a landline on to keep things charged (there are a lot of 'systems' in an ambulance that require power), and then call us to pick it up and we would find everything flat dead, the service work poorly done or half done, and it would need to go back again. A lot of times we just did the work ourselves to save the hassle and lost time. Not every department has back up equipment, so taking a rig out of service is a burden on the community and neighboring agencies.
 I was once friendly with an agency up north, right on the St. Lawrence river which had spec'ed out and bought a very fancy ALS rig, it was a large chassis job with a lot of custom work done to handle the unique aspects of their response area, it carried and supported a lot more gear than a normal ALS rig. But the brand new unit came with a lot of brand new factory issues (shorts, open grounds, lights wired wrong, intermittent connections, mechanical issues, etc). Every time they found a new problem they had to take it to Syracuse for service, over an hour away and using two drivers and two vehicles each way. Every time it was there for a week or more. I think it took them 4 months to get it 'mostly right'.
 "E" vehicles are built to different standards and require a lot more maintenance because the risk is much higher for someone getting hurt if there is a failure. For instance, did you know that the cab of a firetruck must support the entire weight of that vehicle (loaded) when it is upside down on it's roof without buckling? Having said that, I wish the manufacturers would keep that in mind when they build and test these things. I don't think I have ever seen a new rig get delivered and then not have any issues within days, weeks, or months that did not require fixing or rework. Most times it is small, but sometimes people nearly got killed because of sloppy work or poor engineering or shoddy quality control.
Crusarius
Funny you bring that up. Our new 4wd light rescue truck came with the wires powering the entire box ziptied to the front driveshaft. First thing we did when we put the truck into service was lock the front hubs.
Bet you can all see where that went :)
brand new truck just put into service taken out of service instantly!
sawguy21
Well, that wasn't very bright! ::)
Old Greenhorn
OK, well I have never seen or heard of something that incompetent, but you made my point, in part. The next question is, how long did/will it take the builder to make it right and get you new rig in service? If they did that, I have have to wonder what you are going to find down the road. If I were an officer in your company, I would have my guys going over every inch now looking at every wire connection on every terminal strip, checking underneath and checking every bolt for tightness, then giving a list to the department lawyer. I'd want them to have their techs in the station at 9am Monday morning and not leave until you accept the truck.
 Nothing enrages me more than this. These folks have completely forgotten that they are building vehicles that are used to save lives and property, but more importantly they are to keep the firefighters on them safe as they do the most difficult work. When trucks get people killed because they were put together poorly, that is unforgiveable.
 I don't suppose you could share the builder's name? Maybe in a PM? I'd like to pass the word around so others are aware.
Crusarius
Some ways I would like to tell everyone but since they did make it right I choose not to spread bad publicity for one persons mistakes.
However they have not been the best service ppl but are the only game in town for us.
I think it took us another month to get the truck back in service.
But right after we had it back the chief was playing with the light tower mounted on top of the truck. Forgot to put it down and backed into the building. Boom! theres goes light tower #1 :)
Crusarius
Nebraska
I tried to rejoin the wheel falling off
 of the trailer club yesterday.  I turned onto a South bound highway bringing my boat back home and felt a vibration,  slowed down and got to a good spot to pull off and two lug nuts were gone.  ::)
Tightened the remaining three, stole one from the opposite side and drove slowly back toward home.  Kept stopping and checking every couple miles. Fortunately  one of the farms stores was open and a five pack of lug nuts  was obtained  as well as a new tire and rim.  Last half of the ride was fine.  I should have checked them a few miles into the trip home.    Had the tire wrench handy... Much better than falling clear  off  though..
Old Greenhorn
Kick Save, And a BEAUTY! 8)
Nebraska
Dumb thing was is I know I was the one who had the wheel off of that side early last spring..... I swear I put the impact wrench on it after I let the jack down. The rim was on the side that shucked a bearing in Fargo last summer when my buddy that owns the other half of the boat had it up in Minnesota  fishing... don't know if it messed it up then, oh well it's got a nifty new one now...
Resonator
Quotemy buddy that owns the other half of the boat
So it's a partner-ship? ??? ;D
Wudman
It was my turn today........for the second time in 30+ year career, I had to call somebody to retrieve me.  I was looking at a road that I am moving my contractor onto to fix.  It had been chewed up pretty good.  I slid over in a set of ruts and there I stayed.  Reached under my toolbox for my shovel and it was not there.......maybe for the best as it was well north of 90 and I didn't have any water in the truck as I was just "riding and looking".  Of course I didn't have any cell service.  I walked about a mile back to a hill and was able to text my wife.  She called my Brother-in-Law that lived a few miles from where I was stuck.  I couldn't place a voice call, but he found me in short order.  Winched me out with a 9,000 pound "Badlands" winch and then had to self recover as he couldn't move out of his tracks.  Since there are no pictures, I guess it really didn't happen.  Note to self......remember how to walk when things get rough.  Second note to self......fix the 4 wheeler so you can ride into those places.
Wud
Charlie Daniels
Oh man, that's embarrassing.  I'm glad I've never gotten my truck stuck and had to call my neighbor to come pull me out or have to call the local FD and have them come and pull me out with a brush truck.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
sawguy21
Nebraska
Stuck, out of fuel, never....
Crusarius
I dunno what you guys are talking about. I have never been stuck. Just slightly delayed :)
https://rockmodified.com/me/woody0054.JPG
Old Greenhorn
Stuck? No. Just detained pending mitigation.
Southside
At first was wondering how you found a mud hole there Wud, not sure they exist right now - maybe after Friday.  Like the others I am sure glad I never had the frost come out of the road 50 miles in the woods and sink my truck to the frame while I had to wait for a 50,000 lb wheel loader to come and pull me out, in the days before cell phones where you had to call on a radio that everyone in scanner land listened to, yup - glad that never happened.
Wudman
I was up in the northern frontier where they had 5 1/2 inches last week.  The water was really irrelevant.  The tires were in the air with with the frame bottomed out.  DANG big tired 4 wheeling crowd did me in.
Wud
Charlie Daniels
3rd note to self Wudman: Discretion is the better part of valor.
Today I went to install bookcases and a desk I built.  Everything was going great until I told my son to go get the air hose so we could install base trim.  He said, in a voice that worried me, is it in the truck.  It was a voice that suggested to me that he had not seen a hose.  No hose.  No base trim or any other trim installed.  I would have run to the store and bought a new hose, but I also was going to have to go back to install crown mold, so we just finished for the day.  I have an extra air hose because of the last time I forgot to bring one.  I also have an extra 18 gauge brad nailer from when I forgot to bring that.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
sawguy21
I hate it when that happens. :D
KenMac
This is in no way the dumbest thing I've done but today I loaded my tractor on my trailer to go to a small driveway repair job in the morning. Then I decided I'd probably be wise to fuel the truck up. About half way to the station I realized I didn't have my billfold with me. Only took an extra 20 minutes to turn around and start over. At least no blood was shed. :-[
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB, Takeuchi TB260C
