Did something dumb today.
0 Members and 9 Guests are viewing this topic.
Nebraska
 I just have to move this thread back up....Just got done with a stint of call and have the weekend off. Been a pretty nice day for February about hit 50.. So just before dark I finished unloading the third and final trailer load of fire wood logs  i was getting tired of it and came to the realization...... I had just spent the better part of the day working hard at making more work for myself later..   ::)  I guess i'm set for firewood  which is good, really good actually...... Then I went to unhook a trailer and the sliding part of the jack hung up in the tube a little. I was holding the pin in my left hand and gave it a little whack. Then it promptly freed itself directly into the ring fingernail bed of my right hand.  Which for whatever reason was still perched on the edge of the block I sat under it. Now I have a nifty purple throbbing fingernail.
Old Greenhorn
Sorry man, that sucks. Why is it when we have 'time off' we spend it making more work for ourselves and top that off by finding 'not so smart' things to slow us down.
 I prescribe and alcohol soak, PO.
Nebraska
Self medicating with a pint of stout. :)
Old Greenhorn
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
rusticretreater
I just went and picked up an Woodmaster outdoor furnace off of craigslist.  I made a sled to pull it onto my trailer.  It was all going pretty well.  I was able to jack up the furnace with my floor jack no problem.  Got the sled rails under it, installed the cross braces and tried to winch it up onto my trailer.
The trailer is a landscaping type trailer with the drop down rear gate.  I had beveled the sled rail to slide up onto the trailer but it still jammed.  The gate end was on the concrete slab and I noticed that if I pulled forward a bit, the gate would be on the ground which was about an inch lower than the concrete. So I released the spool on the winch and pulled forward a bit.
I then went to winch it up on the trailer again but I had no battery power.  I then found the battery under the trailer and the negative cable had pulled out of the connector lug.  Its one of the two piece safety connectors.  I had to finangle the lug out of the connector, drive a phillips screwdriver into the end to open it up again.  The old fella I was buying the furnace from went and got a propane torch and some solder and we went at it.  Burned the insulation on the cable pretty good but we got it back together.
The furnace went right up on the trailer after that.  All things considered, a fairly painless outing.  I still think about what would have happened if the battery did some arc welding while under the trailer.  :-\ :-X
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Southside
@Nebraska try 3ml of LA200 IM in your opposite arm.  Guarantee you won't notice the pain in your finger any more.   :D
Walnut Beast
Quote from: Nebraska on February 26, 2022, 09:24:25 PM
Now your talking. Hope your healing ❤️‍🩹 up
 @rusticretreater did you see what I did to my battery last week and posted pics on here?  I dropped a big ratchet strap on top of the battery in the back of my truck.  The ratchet spanned the two terminals and caused the battery to explode.  Part of the strap burned, but I'm guessing that when the battery blew up it put the fire out.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Nebraska
rusticretreater
There's been more than one time I welded a wrench to a fender while tussling with battery terminals.  I now have a designated wrench that is wrapped in tape.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Ljohnsaw
Here's a funny YouTube about something that could have gone horribly wrong.  I've watched a few of his builds.  I like his style.
Big off road skates
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Looks like he needs to build a sawmill.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Old Greenhorn
Quote from: firefighter ontheside on March 01, 2022, 10:32:11 AM
:D :D :D :D :D
Now that's funny right there! ;D
Crossroads
I've gotta ask. Have you used the LA200 on yourself before Southside? I've hit some farm critters with it, and none of them seem to like it, but I've seen it put the curl back in a pigs tail more than once.
Southside
After accidentally shooting myself in the hand with a nail gun in the days of no insurance and no money it was the only option I had available to prevent infection.  I didn't feel any pain in my hand any longer, and it put the curl back into my hair even though I have been bald since the early '90s.
Crossroads
Lol, glad you mended okay, I keep a new bottle on hand, just in case.
Wlmedley
After ruining several blades by cutting my log stops I have been watching them pretty closely.Well today I was about ready to go to the house but I thought one more log as I had several on the deck and an order for 150 2"x4"s.Grabbed a can't hook and rolled one on the mill.Stops all the way down and log rolled off other side of the mill.When I designed my set up I didn't leave much room on offside figuring sawdust and slabs would be the only thing coming off.Wrong!  :D.
   Boy, I'm sure glad I never rolled one completely over my mill! ::) :D :D :D :D
Crossroads
I swear! I haven't done that. Well at least not twice in the same day
I think the only way to never hit your stops is to never put them up.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
Southside
When the clutch is engaged both engine driven hydraulic pumps on my Super 70 are pushing oil to the tune of 18 GPM, I don't recall the pressure, but it's enough that we have trophy markers off the back side of the mill showing just how far logs have gone when launched up and over the backstops, that seems to give them more of an arc to get better distance than just tossing them flat off the back, or at least I have been told.  ::)
wisconsitom
Few days ago put myself in a bind-literally-where I was stuck but had no room behind the rears and the "stuck" was in front of me.  3 feet of sugar snow under front tires, right one down in a hole, and old wood deck steps now wedged behind left rear tire as tractor slid sideways as tires started to spin.  The snow in front of the loose stuff was just the opposite, piled high days earlier and frozen into ice.  No way, nowhere to go forward. Tire jammed in rear.  Bucket push couldn't help in this situation.
So I's gets rocking, 2inches this way, turn steering wheel first this way, to bust out some tough snow on the left side that's hanging me up, but then back the other way REAL fast, so whole works wouldn't slide back down into hole.
On and on, HST oil had to be getting warm🥴, but gradually slightly changed the angle of the machine just enough.....that all I had to do was be willing to have the left rear tire back right up and over that step.  Yisss, good times. Now, with bucket push and rear dif lock, up and over that step and on out of there.  Gotta say, R4s are tough!
Would have been a long and cold walk up out of the woods, all the way to the neighbors, hope he's home, see if the skidder will start, see if we can dig me out of there.
Ask me about hybrid larch!
Crossroads
I'm looking forward to having the faster hydraulics. Only 13 months to go
