Garden build 2025
Started by DDW_OR, February 26, 2024, 04:46:15 PM
DDW_OR
yes there is a Farmers Market on Thursdays during the spring-fall
I am sick of buying a Veg or Fruit at the store and it does not taste like it should
watched a YouTube channel called "More Than Farmers"
she used a Pectin that reacts to Calcium instead of to the sugar. it is called "Pomona's Universal Pectin"
this allows for much lower sugar levels in your jams
DDW_OR
removed a Fir tree and it's stump that was in the way of planting fruit trees
the ripper tooth on the Bobcat E80 worked great
rusticretreater
Your place looks a lot like the disaster my place is right now.  If I finish all the projects, it will be a showplace!
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
DDW_OR
Yellow box is rough location of the greenhouse
Did 2 photos to make a 360 view
DDW_OR
my current well is over 500 ft from the house. the line has a leak that turns on the well pump every 2 minutes.
Directional boring is $25,000, a new well is $6,500
so drilling a new well.
changing the northern room for greenhouse into a well house with two 100 Gallon pressure tanks in blue
the yellow circle is a Honey 9 frame spinner
Yellow boxes are Hives with access to the outside.
the bees will travel through a Zig Zag channel to prevent winter winds from blowing into the hive.
the Green rectangles on the left are raised beds
the gray on the right are in-ground beds
squares are for wind pollination for crops like corn
can you see a wet spot when everything is running?  cycling every 2 minutes implies a pretty big leak, assuming you already have pressure tanks.  if found, can you dig up the line in one spot and repair?  Seems it was not that long ago you put this all in.
DDW_OR
Well and waterline was in 1960 in Montana with metal pipe
I think you are remembering Oregon with plastic pipe
can you hook onto it and pull plastic behind it to pull through?
Old Greenhorn
You know your system better than anyone, but before you drill a new well, have you checked your pressure tank? If the bladder leaked out, has no pressure and the tank is waterlogged, it will also cause short cycling. It's a lot easier to check and fix than drilling a new well.
DDW_OR
In Montana I can leave a water hose running full blast for a week and there will be no pool of water.
I have tried to find the leak
Turned the valve to the house off at the well house.
Watched the pressure gauge
It did not move during the 15 minute test
Turned on
Went to house and turned that valve off
Leak is somewhere between
Pipe is 1 inch
Too small
My neighbor tried a green house with OWB heating the ground with a series of pipes. It cost him 32 cords of wood he had to buy. That idea ran out of steam fast. Our winter is long up here, 9 months. He was also heating the house. He heats the house with regular stoves now and the OWB is long gone. It's an impractical and very expensive way to become self reliant on veg all year.  Green house is only in spring until mid fall now.
They were at one time growing bananas in Newfoundland greenhouses, cost of production killed it. Now in more southern climes the numbers will pencil out I'm sure. Not here. I have also seen other banana operations come and go. In other situations where they move plants outside in summer, mostly what you accomplish is growing a plant with inedible fruit. Not time enough to mature.
aigheadish
Indoor(ish) bees is an interesting idea. I'd like to see pictures of that setup.
DDW_OR
Quote from: aigheadish on April 08, 2025, 07:02:05 AMIndoor(ish) bees is an interesting idea. I'd like to see pictures of that setup.
indoor during winter
maybe all time
DDW_OR
DDW_OR
Turning a cement mixer into a root vegetable cleaner and compost screener
https://m.youtube.com/watch?v=bQba3C_SR8U
Smart little guy you are!!!
DDW_OR
i have a lot of 3x10 metal roofing
plan to make my raised beds 3x10
the 3 ft width will be the 10 ft cut into thirds = 3' 4"
then in the middle of the 10 ft i will use 1/2 inch PCV pipe ( green ) with glued on end caps ( Blue )
corners will have the wood on the outside. ( Red )
will look something like this
