when you have too much wood, do you sell your saw?
Started by opticsguy, March 04, 2012, 09:06:31 AM
Overlength
Build portable storage buildings with the wood, that you can sale, or store more lumber in! Or both! Or sale portable building filled with woods!
Woodmizer LT30, Solar Kiln 400 bf
Okrafarmer
Quote from: Overlength on March 05, 2012, 12:53:17 PM
Oh, that might be the best idea yet!
Now selling Logrite tools!
POSTON WIDEHEAD
Quote from: red oaks lumber on March 04, 2012, 10:17:14 PM
sheds  isn't that topic in the outdoor section?
I think it's in all the sections.  :D
Okrafarmer
Overlength
PC-Urban-Sawyer
No matter how hard we try, we can't get shed of it...
Herb
eastberkshirecustoms
I don't give a shed!!!.... but I would take a shed ;D
Okrafarmer
If anybody gets too much wood, just let me know when you have a truckload's worth you don't want!
zopi
too much lumber is as bad or worse than not enough...with the mill down, all the lumber I have on hand is high val stuff...red and white oak for some particular projects..when what I really need is pine siding and battens...
oh bugger.
that being said..attractive three and four rail fence eats up a buttload of lumber in a hurry.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
I shed'nt think that you would have any problem finding some pine.
Overlength
I've heard it shed before, bigger cover is better.
PC-Urban-Sawyer
Just remember to keep it klean or Jeff might send it to the wood shed!
Herb
Overlength
You shed get your mind out of the gutter. Bigger, or more covered space is better, or so its been shed.
tyb525
I've got lots of lumber, but my problem is it's all hardwoods, and it kills me to use it for low-value things like pallets and buildings that softwood would be better suited for :'( I do use some of it up every now and then, but it's still sad every time :D
When I grew up, Grandpa and his youngest son on the farm built everything using walnut lumber. The farm had a lot of walnut trees that they would sell some logs, ending up with the upper logs that they had sawn into lumber. The lumber ended up in cattle gates, portable hog houses, sheds, etc and have to admit was cheaper than lumber from the local yard.
Okrafarmer
Handy Andy
  There was a thread a while back, with pics, showing how to build frames and a top for your wood pile, my sheds are full and planning to use those plans to make a stack outside.  Looking forward to being able to use the skidsteer to stack it.  Humping it up into a pile in a barn is tough. I started doing this to supply my wood addiction, figured if I sawed my own wood, could afford to build projects.  Used to be particular with wood, cutting around defects, but have found sawing my own wood, there are no perfect boards.  So I just put the defects front and center.
My name's Jim, I like wood.
