Useful sawmill mods
0 Members and 14 Guests are viewing this topic.
learner
Pete it actually seems to work better than the original flap.  It's a bit stiffer so it really hugs the log.
WoodMizer LT40 Super Hydraulic, MF-300 FEL, Nissan Enduro 60 forklift, 2 Monkey Wards Power Kraft Radial arm saws, Rockwell series 22-200 planer, Prentiss 210 loader
petefrom bearswamp
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
drobertson
Nice mods! like the clear deflector,  and the board deflector too!  nice stuff,   david
Bibbyman
If you have the Lube-Mixer option on an LT40 series mill, you probably curse each time you take the side shield off and put it back on.  We'll,  I thought about it and didn't see why it had to be where it was.  If it were up on the turned up edge of the water tray it would be out of the way.
Well, yesterday was the day.  I soon found out that if you just raised it up and tried to install it on the edge of the tray,  you couldn't unscrew the bowl.  So just to try something,  I turned the bowl assembly so the top was flat against the edge.  We sawed a couple of hours yesterday and everything worked so it just may be fine there.
Just for good measure, we removed the bunji cord from under the try.  As our mill is stationary, it was never used.
In any case,  the side shield went back on MUCH easier.
Sawing since '94
Chuck White
Good one, Bib!
I usually use a nut driver to remove the side shield (except for the one that's towards the engine) and the top-front bolt is right in line with the clamp (pita) that holds the gas hose.
Mine has been adjusted too.
Thanks for posting.
terrifictimbersllc
I put these 12V trailer clearance lights on the front of my hydraulic box.  They're wired to the motor lead side of the hydraulic solenoids.  Why?
Those are my wife's toes, she's pushing down on the loader lever.  When hydraulics are working normally, both lights are on.  Originally, I mounted these to be able to see when one of the solenoids fails, rather than waiting to find hydraulic fluid running out of the box.  These lights have already proved useful in another way.  Several weeks ago I saw that the lights were dim even though the hydraulics were working.  I checked voltages and found the alternator wasn't charging the battery.  I called WM,  and very quickly was led to discovering that the green wire from the alternator had a bad connection at the 16 pin connector, which was easy to fix.  If I hadn't seen this I might have run down the battery and been unable to start the sawmill.  It is reassuring to see these lights on bright,  whenever I use the hydraulics.
I like them.  They would also be dim if/when the button was not making good contact with the strip.
terrifictimbersllc
Quote from: Magicman on January 06, 2013, 04:49:36 PM
Thanks. Or when the hydraulic microswitch fails, when my battery is going bad, or anything else affecting battery voltage. I don't have to worry about that button anymore though,   with help from Bibbyman and PNyberg (posts earlier in this thread), last summer I did the 1/0 gauge welding cable replacement of the hydraulic strip.  What a difference!
DR Buck
Quote from: Bibbyman on January 06, 2013, 10:22:08 AM
If you have the Lube-Mixer option on an LT40 series mill, you probably curse each time you take the side shield off and put it back on.  ................In any case,  the side shield went back on MUCH easier.
I'm going to have to look close at my mill tonight.  My mill came with the factory installed lubmizer.   I don't ever recall having an issue with the lubmizer bowl  when taking the side shield off and on.     smiley_headscratch
I had that shield off of my sawmill this morning.  On my sawmill, I loosen and remove the 5 bolts and then the shield pivots out from the bottom and passes by the wiring terminals on the up/down motor and then lifts downward and out.  The top edge of the shield is the last to come out when removing and the first to be reinserted when installing.  I also have a retrofitted Lube-Mizer.
Other LT40 versions may be different.
Peter Drouin
Quote from: Magicman on January 07, 2013, 02:03:03 PMOn my sawmill, I loosen and remove the 5 bolts and then the shield pivots out from the bottom and passes by the wiring terminals on the up/down motor and then lifts downward and out.  The top edge of the shield is the last to come out when removing and the first to be reinserted when installing.
thats what I do :)
YellowHammer
This a followup to a previous post (702 on this thread) where I've been working on my board return system to make it more controllable, and fixing it so that it would release the board where I wanted, not just where it wanted.  I also desired to return shorter boards all the way to the end of my loading table, and virtually drop it on my lumber stack, as opposed to just dropping to the mill bed about halfway back, which kind of defeats the purpose of a board return.  Normally, I have to reach forward to grab the dropped board to drag it to the loading table with one hand and this got old real fast, especially with lots of heavy, boards.
So I welded a small lip to the bottom of the board return arm and now I can return most boards all the way across the table and release them at any point by just reversing direction on the mill head.  Much easier and more controlled.  I'm still experimenting with the shape of the lip, but here's a picture and also a video on it returning a board with me stopping at a few locations on my table, then finally dropping it where I want it.  I put a few thousand bdft through it in the last couple weekends and it seems to work pretty well. I only had to reach for a few boards, and was also able to push the ones I wanted right to my stack with no real handling.  This was one of the first configurations, now I am experimenting with a slightly larger, more tapered flange.  A very simple mod, but pretty effective.
http://youtu.be/E5upimQu1YU
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
DR Buck
Quote from: YellowHammer on January 21, 2013, 11:09:16 PM
So I welded a small lip to the bottom of the board return arm and now I can return most boards all the way across the table and release them at any point by just reversing direction on the mill head.  Much easier and more controlled.  I'm still experimenting with the shape of the lip, but here's a picture and also a video on it returning a board with me stopping at a few locations on my table, then finally dropping it where I want it.  I put a few thousand bdft through it in the last couple weekend and it seems to work pretty well for such a sImple mod, I only had to reach for a few boards, and was also able to push the ones I wanted right to my stack with no real handling.  This was one of the first configurations, now I am experimenting with a slightly larger, more tapered flange.  A very simple mod, but pretty effective.
Nice mod.   Keep us informed of any improvemnets you come up with.   I might have to do the same on my mill.
YH, I like your mod. :)  Think I'll do something similar for my TK.
Let us know if ya make improvements.
rmack
it's simple, and it works... pretty tough combination to beat.  8)
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
ElectricAl
Pretty nice mod YellowHammer.
In a quest to keep from plugging up the LubeMizer upper jet, I made a plastic guard.
The prototype was a piece of Milk Jug. Worked good enough to pass the "Proof of Concept" stage.
Next was the bottom corner of a one quart oil bottle. I just let it rub on the blade until it had self adjusted to a slight gap. That took about 2 weeks.
With the gap set we enter Long Term Testing.
Which may only be a couple weeks until I dream up a slight modification.
Nothing like Modifying a Modification.   ;D
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
LeeB
What blades are you using Al? I don't recognize the profile.
pineywoods
Quote from: LeeB on January 22, 2013, 11:15:35 PM
Me neither, that is sure some wicked gullet..
ElectricAl
Lee & Pineywoods.
That is actually a WM 9 degree that I pushed the set out to 34. We had just sawn a bunch of frozen Pine.
The Gullet looks funny because there is Sap build up on the back of the tooth. Plus the bottom of the Gullet is hogged out a little extra.
Good Eye
LeeB
Do you do your own sharpening and have you sharpened them? I use WM 9° also and still the configuration looks different to me. It seems that the transition from the tooth face to gullet is very acute. Did you modify the cam?
Brucer
Quote from: ElectricAl on January 23, 2013, 06:34:00 PM
... The Gullet looks funny because there is Sap build up on the back of the tooth....
The tooth on the very left shows up the buildup on the back of the other teeth.
Bruce    LT40HDG28 bandsaw
ElectricAl
Lee,
We grind our own blades with a WM Drag Sharpener.  The Face to Gullet transition is pretty tight and could use some extra radius.
We normally saw with 7 degree and 10 degree blades, so the sharpener has a 10/32 cam on it.
Only had to saw 2700' of Pine so I never changed the cam when I put the 9 on. There are 3 other cams in the draw to choose from, but I chose to ignore them.
We are going to use up all the 9 degree as soon as possible then switch to CBN  .
The CBN wheel is the same for 7 degree and 10 degree.
It sure is nice to drag the board back and drop it right where I want it.  I welded up my rendition for a TK 2000 last week and tested for proper operation.  Worked great so I painted it and got it installed permanent today.
Thanks for the idea...every step saved makes for faster/easier production.
YellowHammer
I glad to hear that it also works on TK's.  I've already gotten so used to mine that I don't think I could go back
YH
YellowHammerisms:
papow22
Quote from: Bruce_A on September 09, 2004, 06:23:29 AM
Are other mill so complete that they don't need these updates?
To some other sawmill owners this site only "Woodmizer".......But it pays to go and snoop around to snag some ideas also Lm2000 owner operator. :snowball:  :D
Lives to do sawdust,run a trapline,hunt big game,live life to it's most.Got 4 mills a circle mill,(2 band sawmills) Norwood's 2000, Trim Saw,Beam Machine (chainsaw mill).
