Did something dumb today.
Started by firefighter ontheside, February 26, 2019, 10:48:19 PM
0 Members and 11 Guests are viewing this topic.
Crossroads
No worries Doc, I deserve some razzing in this one. At least it was an easy fix 😝
Lko67
My daughter bought these for me probably 5 years ago. Only wore them a couple times just never thought to put them on. Worked in the woods when younger and cut firewood all my life and never had them.
Well yesterday I had some locust to cut down to make raised garden beds and for some reason decided to wear them and this happened.
Luckily was coming down to idle. I will be wearing them from now on for sure.
Guess the one above was watching out for me.
I recommend everyone should wear them. It can be the difference between a good day and a bad one.
tacks Y
Lko67, I keep thinking I should buy a pair.
I am over near Warren Pa. Do you get elk over your way? Looking for someone to point me in the right area to look for sheds. Or is it mostly private land?  Thanks
Well, you should be posting in the did something smart thread.  I have chaps and don't wear them all the time, but wear them a lot of the time.  I need to buy some chainsaw pants to have too.  I'm sure they would be nice in the winter too, even if just to keep me warm.  I wear my chaps when weed eating in the summer too.  If I wear tall boots and the chaps I can keep my legs clean.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Crossroads
In my younger days chasing landing under a 100' Berger tower, I glued inserts inside of my tin pants. I bumped knots on 10-20 loads a day and never got into my legs. Now I only wear chaps when I'm limbing, but every time I start a saw. The little voice in my head asks "where's your chaps dumby?"
Lko67
Tacks
I'm in Clinton county about 45 minutes from main elk population. A lot of ground is posted. Game Commission book is probably easiest way to find places not posted.
Crossroads
Quote from: Lko67 on March 03, 2023, 08:53:32 AM
Tacks
OnX hunt maps will show you land ownership and property lines. I recently purchased BaseMap and so far I like onX better. Accuracy of property lines can vary with the overlay, so they are only for reference.
Quote from: Lko67 on March 03, 2023, 08:06:17 AM
I'm assuming the close-up photo shows chaps and the pulled thread the chain marks.
I don't go without the chaps on. 40 years ago this year just prior to leaving for a CO 2-week elk hunt, I locked up my saw chain in my chaps when the running chain caught a small branch and the chain hit me just above the knee cap. Saved the day, the elk hunt, and won't start the chainsaw without them on (3rd pair now as I replace when they get worn, dirty, or marked up).
SawyerTed
I'm on my third pair as well.
My first set of chaps were a Christmas gift AFTER I had a kickback into my shin that required emergency surgery to fix.
I learned the hard and painful way.
sawguy21
How come too many of us had to learn our lessons that way? To soon old and too late schmart! ::)
Southside
Not only wear them, but wear them the correct way.  They need to be fastened snugly around your legs as they will walk into the chain and pull the chain into them at the same time, so if they are floppy and loose on your leg the chain can pull them around and still get you before it stops.  This is a bigger issue with apron style chaps over full wrap.
White Oak Meadows
Don P
Lee, have you healed up yet?
Mine was minor and should only come to fruition now that I replaced it.
The check engine light went on in my wifes car, you all will remember her favorite deer hunting Honda. It reads that the rear O2 sensor is kaput so for a week now I have been tossing the shop looking for the tool. She of course is hearing all kinds of ominous sounds because of that light bulb so I gave in and bought a new tool for it yesterday. Well, anything to do with old cars and exhaust is just about a losing battle but with some careful angle grinder work and a plain old box end wrench I had it R&R'd, in a mere whole afternoon  ::). I'm figuring about 48 hours till the old tool surfaces and they crawl off somewhere to hide  :D
SawyerTed
My problem is chalk lines.  Every project seems like I have to buy a new one.  I must own 5 of 6 but only know where the new one is.  I'm glad they aren't expensive.
Don P
I feel your pain   :D
I wonder why you can't buy a card of a dozen end hooks?
doc henderson
my favorite one is a fat max.  they used to give you a little one with a speed square at the box stores.
Southside
Don't mix the orange and blue chalk thinking it will be an easy to see color.  I have re-filled that one I don't know how many times and it still manages to only grab that mixed stuff, of course that is the only one we ever find.
White Oak Meadows
Don P
You haven't lived till you smurf yourself  ;D
Machinebuilder
Blue chalk has nothing on hi spot blue
That stuff gets everywhere and doesn't wash off easy.
Dave, Woodmizer LT15, Husqvarna 460 and Stihl 180, Bobcat 751, David Brown 770, New Holland TN60A
jpassardi
Does anyone else find that red chalk seems to never wash off?
Don P
One of the golden rules, red is permanent, get the new guy off the concrete with that red box!
When you mix red and blue it is a Jimi Hendrix line  ;D
We would snap in blue and correct in red if there was a mistake. Red trumps blue, or something like that.
Crossroads
Caulking guns are my nemesis, I have no idea how many I have, but it seems that I have to buy a new one every time I need one. I bought a new one a few weeks ago, just so I could find one I already had. It worked! I found 2 more 👍🏻
Resonator
Things like torx bits and drill bits I buy regularly. I misplace them, and only when I do a full shop cleanout do I find all of them. I've learned the hard way to have extra's handy when a project comes up, rather than waste an hour walking in circles searching. ::)
And chalk lines... don't use them anywhere around drywall you plan to paint white. :o
Independent Gig Musician and Sawmill Man
Live music act of Sawing Project '23 & '24, and Pig Roast '19, '21, & '24
Featured in the soundtrack of the "Out of the Woods" YouTube video:
"Epic 30ft Long Monster Cypress and Oak Log! Freehand Sawing"
Chuck White
Quote from: jpassardi on March 27, 2023, 08:18:57 AM
YES, I still have a red chalk line on the back side of my leanto that's been there exposed to the weather for 8 years now!
Ljohnsaw
Quote from: Chuck White on March 27, 2023, 01:56:58 PM
I had another Forumite make some cedar fence boards for my niece. Her husband hired a crew to put up the fence. They used red caulk to mark the screw lines. A power wash probably would have cured the issue if nephew didn't seal up the fence first with some clear oil.🫤
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
