Dynamic Green Products Inc.
Author Topic: Did something dumb today.  (Read 64145 times)
Offline firefighter ontheside
  • I like trees.
« on: February 26, 2019, 10:48:19 PM »
I made a cut and then went to raise the head so I could return it for the next cut.  Apparently I lowered the saw on accident instead of raised.  When I pulled the saw, the back of the blade hit the log and the blade came off the wheels.  At first I thought the blade broke, then I realized what had actually happened.  The blade appeared undamaged, but I was leery about putting it back on.  I figure at the least, some teeth got damaged.  Who’s done this?
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Woodpecker52
Re: Did something dumb today.
« Reply #1 on: February 26, 2019, 11:01:14 PM »
Happens more times than I care to admit, forget which way to move dial.  Blade should be ok.  I like to finish a cut, turn the log raise the blade up about a 1/4 of a turn and pull back and do not see the bump sticking up till it catches the blade and everything comes to a stop. Or the all time bonehead, turn about a 4x 10 cant up on high side forget to raise up stops and have it fall over in the middle and jam the whole works up and end with a zig zag blade.
Offline Southside
    • White Oak Meadows
« Reply #2 on: February 26, 2019, 11:34:56 PM »
Nope, not me, never hit the right trigger instead of the right thumb button.  ;) That's my story and I am sticking to it!!
Offline Percy
  • Resident trouble maker
« Reply #3 on: February 26, 2019, 11:59:00 PM »
After 11,500 hours, my blade door on the mast side has a jagged hole in it where countless  blades have hit Because of various unintelligent moves. A common one for me is leaving the feed lever in the business position but having the speed control knob completely off. The lube mizer keeps squirting and, using pdiesel for lube,  enough of it accumulates on the blade. Hit the auto clutch on and the blade spins out on the diesel causing it to fly off, just as it’s winding up. I could go on for many chapters of Dumbness. Should write a book called Percy’s Pinheaded Sawmilling Techniques.
Offline Rhodemont
  • Logging and milling just a hobby
« Reply #4 on: February 27, 2019, 05:35:10 AM »
When sawing or logging I have a prescription for one-dumb-aday and use it.
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T and now a CS-361P
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #5 on: February 27, 2019, 06:35:13 AM »
I've done it maybe twice since I've had my mill, then I started following what's written in the book!
When the blade exits the cut, disengage it for the gig back to the front!  ;)
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #6 on: February 27, 2019, 07:22:17 AM »
A better question might be "who hasn't done this........... Yet." :D :D
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
  • I like trees.
« Reply #7 on: February 27, 2019, 07:39:47 AM »
Thanks for the replies everybody.  I enjoyed them all.  The thing is, I always disengage.  I must have disengaged and then tried to go back while it was slowing down.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline doc henderson
« Reply #8 on: February 27, 2019, 07:48:18 AM »
This is why I am putting a "laser" on mine.  I at least one time hit my setworks down button before I had cleared the back (near) end of the log and tried to stretch my blade.
"laser" indicator for sawmill. in Sawmills and Milling
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #9 on: February 27, 2019, 08:09:07 AM »
   Yeah, I have bumped the down toggle on my setworks after raising the head then lowered and knocked the blade off. Usually no damage is done, just a little embarrassment if others happen to be watching.
Offline Crossroads
  • let’s make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #10 on: February 27, 2019, 08:54:58 AM »
I’ll take the 5th 😎😎😎😎😎
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger
Offline petefrom bearswamp
  • 70-13 still feel OK and am retired
« Reply #11 on: February 27, 2019, 08:57:09 AM »
Been there done that multiple times.
No cure for it in my case as inattention is a constant trait of mine
Kubota 900 RTV
Polaris 570 Sportsman ATV
241 acres of woodland
Offline Alyeska Pete
  • Location: In the Catskill Mountains, west of Kingston, NY
« Reply #12 on: February 27, 2019, 11:31:58 AM »
Now we know why Cook always used plywood for blade covers. In recent years they caved in to the "me too" market pressure and went to steel covers. I'm lucky to have bought my mill before the change. I have yet to trash a blade by knocking it off on the return, despite having done it at least several times a year. I strive not to do this unless I have an audience.
au·di·ence  Dictionary result for audience
/ˈôdēəns/
noun
  • 1.
    the assembled spectators or listeners at a public event, such as a play, movie, concert, or sawmill demonstration.
  • I like trees.
« Reply #13 on: February 27, 2019, 11:58:50 AM »
Pete, I feel like you might have added that last part.  Lol.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline Sixacresand
« Reply #14 on: February 27, 2019, 01:32:58 PM »
There are so many things you have to be aware of while milling,  Being tired and hot can cause lose of focus.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum
Offline gshd1
« Reply #15 on: February 27, 2019, 02:47:53 PM »
ayup it happens
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« Reply #16 on: February 27, 2019, 03:10:10 PM »
that's just nonsense.  it's NEVER happened in bullard, texas!
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
  • I like trees.
« Reply #17 on: February 27, 2019, 05:23:30 PM »
I looked closer at that blade today.  One tooth was almost completely sheered off.  I think I will not send that back to resharp.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Online GAB
« Reply #18 on: February 27, 2019, 07:48:06 PM »
You are definitely not alone on that one.
Don't ask me how I know.
Gerald
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Offline starmac
« Reply #19 on: February 27, 2019, 08:37:11 PM »
Well, there is a saying on the haul road, that there is two kinds of truck drivers, those that have crashed and those that are going to.
Some things are just a whole lot alike, and yea I have done it, but I ain't admitting it.
i pulled a dumb-dumb...
Started by Dan_Shade on Health and Safety
Last post August 06, 2005, 06:10:46 AM
by sawguy21
I'm such a Dumb---
Started by jargo432 on Firewood and Wood Heating
Last post March 10, 2016, 06:43:15 PM
by jargo432
How dumb can I be? VERY!
Started by tmbrcruiser on Sawmills and Milling
Last post April 14, 2017, 09:22:37 PM
by Magicman
Wow, that was dumb...
Started by EmannVB on Sawmills and Milling
Last post December 23, 2010, 05:06:52 AM
by crtreedude
