Author Topic: 4" vs 4.5" Hydraulic Splitting Cylinder  (Read 1847 times)
Offline Rougespear
  • Salmon Arm, British Columbia
« on: October 07, 2019, 09:32:29 PM »
I'm in the stage of planning my firewood processor build.  I am wondering on people's thoughts of a 4" vs 4.5" splitting ram through 4 and 6-way wedges?  With the 4" I can get the cycle time down a bit running a 30gpm hyd pump but I sacrifice power.  I NEVER split crotch wood... almost always relatively straight grained birch, fir, larch, pine and cedar that arrives by the truck load.
For comparison, my only experience is with my 3.5" 12-ton 2-way splitter I currently use.  It does well up past 20" rounds of fir... but I somehow feel it wouldn't handle a 6-way wedge at all.
Thanks!
Custom built Cook's-style hydraulic bandmill.
Offline sawguy21
Re: 4" vs 4.5" Hydraulic Splitting Cylinder
« Reply #1 on: October 08, 2019, 01:34:56 AM »
You are correct about  the smaller ram having more speed but less power but I'm thinking you will want more than 4.5" with a six way. They need a lot of power which may bend the shaft. I modified a 30 ton portable splitter, cranked up the pressure relief valve and that was the result. The head which my boss fabbed was a work of art though. :D
Offline Al_Smith
« Reply #2 on: October 08, 2019, 04:46:33 AM »
Much ado about cycle time on home builts .I've got a home built with a 5" cylinder that will obviously split anything and it's fast enough I don't run the engine at full throttle,don't need to .
Now were it two strapping 20 year olds feeding it cycle time might be a big deal but an old  70 plus year old it just wears you out to try and keep up with the machine .That said were it myself I'd opt for the 4.5" .
Offline Al_Smith
« Reply #3 on: October 08, 2019, 05:00:54 AM »
Now another thing about bending cylinder rods .Some designs they just anchored the cylinder on the back side which is more prone to bend the rod than anchoring the front and back and having the slide built as such it won't  rise up or allow side movement .Mine BTW is anchored with four  1" grade 8 bolts and a stop block .So what I'm saying is it's all in the design IMO .Build it battle ship strong it will last forever .
Offline Hilltop366
« Reply #4 on: October 08, 2019, 09:19:23 AM »
Lots of on-line calculators available, by using a couple of these https://www.baumhydraulics.com/Home/Page/speccalculators you can get a idea of the differences between the two sizes.
If I did it right and used 2500 psi for pump pressure you would be looking at around 8000 lbs more pressure with the 4.5" and 1.5 more seconds in cycle time (extend and retract) not counting time spent at the high pressure/low speed stage of the pump.
That is assuming you are using a two stage pump.
Offline Hilltop366
Online GAB
« Reply #6 on: October 08, 2019, 09:28:54 AM »
On the return cycle you are not trying to do any hard work.  So if you could find a say 5" cylinder with a 4" rod you would pump a lot less oil for retraction of the piston and it would be less apt to bend. i.e. the best of both worlds.
GAB
Offline Rougespear
« Reply #7 on: October 08, 2019, 10:15:49 AM »
Speed is an issue in this case as the splitter has to cycle at a speed suited to the cutoff saw.  I think I'll grab the 4.5" for now and build the splitter's push block "battleship strong" haha.
I will be using a 30gpm single stage pump to run the splitter and hydraulic saw.
Thanks for the input
Offline doc henderson
« Reply #8 on: October 08, 2019, 10:21:42 AM »
I have a 5 inch cylinder, with a 2 inch rod.  32 inch long cylinder.  a 18 hp motor with  a 28 gpm pump 2 stage.  I would want the most power if you are going to do a multi splitting wedge.  no fun spending time getting a 6 way unclogged. sounds like mostly soft woods.  the retraction time is not bad with a detent valve.  if you are using this as a business, I would tend to overbuild, especially if your customers and family depend on it.  If you are using a power beyond plug, it is my understanding that both operations will not be happening at the same time.  so the saw would occur and then the splitting.  At 30 gpm, cycle time should be ok.
Offline Rougespear
« Reply #9 on: October 08, 2019, 10:30:22 AM »
When designing to split 20" rounds, how close to the center of that (10") is a good place to have the splitting ram push?  Or in other words: how high off the I-beam is the cylinder's centerline?
My income won't depend on this processor, but I do plan of commercially processing as a side gig (one of many haha).
Offline barbender
« Reply #10 on: October 08, 2019, 11:57:47 AM »
A 4.5" cylinder should have a pretty fast cycle time with a 30gpm single stage, and a lot of power!
« Reply #11 on: October 08, 2019, 12:53:59 PM »
so my 5 inch cylinder centers are 5 inches up off the H beam slide surface.  it leaves 2 inches under the external cylinder.  I used to have a 10 inch tall pusher and this pushed on the center of this.  my splitting wedge is 18 inches tall and my BIL was splitting a gnarly 30 inch log and it pitched back over the pusher and bent the top slightly.  all my pusher parts are 3/4 inch plate.  I straitened this and added more plate to the pusher with reinforcement, making it 16 inches tall.  I have had no issues having the rod attach  at 5 inches, and pushing up to 32 inch logs.  with a 16 inch pusher and an 18 inch wedge.
I used a 32 inch long cylinder, and use stops to make it a shorter cycle time for my goal of 16 inch firewood.  the 10 inches of stops makes it a 22 inch opening for odds and ends, shooting for my target length.
« Reply #12 on: October 08, 2019, 01:00:07 PM »
I made an 8 way wedge that fits in front of my 18 inch single wedge, but do not use it often as I am splitting hardwood such as mulberry, elm, oak.  any branch points ect. can really jam it up.  As you prob. know, each component will have to tolerate the pressure and force generated by your machine, and the occasional whoops when a split pushes the whole thing sideways.  I like the 2 stage pump as it is slower at the highest pressure, giving you a chance to "Abort" if needed.  In a huge log, I will back up some part way into the split to let the log center itself, so I do not torque anything.  in case the split does not line up with the rod and pusher exactly.
« Reply #13 on: October 08, 2019, 01:24:29 PM »
my pump/valve is set to bypass at 3k psi x 2.5 x 2.5 x 3.14 = 58,875 pounds of splitting force.  if I did the math correct, and if not I am sure someone will chime in!!! :D :D :D.  your flow is 30 gpm, do you know your psi?  how are you running the saw and the pusher?  off the same pump with power beyond?  Ts? separate pumps?
Offline moodnacreek
  • Sawin by the notches
« Reply #14 on: October 08, 2019, 07:02:59 PM »
Go for a 4 1/2" with 3" rod. It will be worth the cost of having one made if that's what it takes. We have been running one for years with just over 25gpm. 30 will be better than ours and will have a nice return.
Offline Rougespear
« Reply #15 on: October 08, 2019, 10:55:33 PM »
Thanks everyone for the thoughts.  Really helps solidify my plans.
Offline blackfoot griz
« Reply #16 on: October 09, 2019, 09:13:10 AM »
One other consideration would be the ports on the cylinder. The ports need to be big enough to handle the flow. Restriction= heat build up.
Offline Rougespear
« Reply #17 on: October 09, 2019, 10:29:49 AM »
Most everything I see off the shelf runs SAE8 ports... so probably on the small side of passing 30gpm.  I could upsize them... just haven't welded on hyd cylinders in my life before.  I'm a good welder, just have to figure out the process for cutting out the old ports and welding in the new ports in such a fashion to NOT destroy hyd seals.  I'm open to suggestions as it seems few people take the time to enlarge ports on shop-built splitters.
Offline Nathan4104
« Reply #18 on: October 09, 2019, 10:45:14 AM »
I have a 3.5 cylinder on my processor, but I had the rod changed out to a 3 I believe.  (16 or 20gpm pump I believe) It was as big as the machine shop could put in. They also opened up the ports. It made the return about a second faster, which does not sound like much till you realize you wait 6 seconds per log to make the next cut, and how many logs per cord.... makes minutes! And is just satisfying to see it retract a bit faster!
I split mostly softwood and birch through a 4 way wedge no issues.
Good luck on your build!
Offline Al_Smith
« Reply #19 on: October 09, 2019, 12:40:07 PM »
IMO it would be very difficult to bend a 2" rod even on a 5" cylinder if the anchor points and the slide are solid and true to the point of thrust .It's all just the laws of physics .
Then comes the tonnage rating .A 5" at 3000 PSI is just short of 30 tons,a 4"  just short of 20 which gives rise is to how pray tell how can  a 4" be rated at 27 tons ?They lie ,simple as that .
Then comes what do you want to do with it ,run it wide open all out or make it last .Directly from a Parker -Hannifin design book it shows the increased longevity from just a pressure drop of 500 PSI .
moved
MOVED: Looking for 4" x 24" hydraulic cylinder with 3" rod diameter
Started by chet on Firewood and Wood Heating
Last post August 16, 2015, 09:05:42 PM
by chet
Wood splitting "technique"
Started by jaustin on Chainsaws
Last post February 05, 2005, 08:02:51 AM
by Engineer
looking to hear some splitting tips on splitting 30"dia. plus rounds with my tw5
Started by adamant on Firewood and Wood Heating
Last post November 12, 2015, 11:31:32 AM
by bigblue12v
Wood-Mizer Hydraulic Pump "HOLD ON" Circuit?
Started by Ga Mtn Man on Sawmills and Milling
Last post April 04, 2014, 01:02:30 AM
by Brucer
