Woodmizer LT40SH CG-13 engine problem
Started by Country Bumpkin, May 31, 2025, 11:58:47 AM
Country Bumpkin
I have a Wood-mizer LT40SH with a Nissan CG-13 engine that is not running right. I need to manually manipulate the choke to cold start it and it needs to really warm up before it will function properly. There is a small plastic gear on the throttle linkage with broken cogs that I suspect might be the culprit. As these engines have not been used on these mills for two decades now, Wood-mizer has not been able to help me. I don't even know what the part is called to I can search for it. I saw a previous post here were another member was having the same issue but the thread ended not saying if his issue was resolved.
First, Welcome to the Forestry Forum.  After you get your problem solved, come back and visit for a while and tell us a bit about yourself and your sawing.   :thumbsup:
Contact @MartyParsons at PA Wood-Mizer.  LINK
MartyParsons
Hello
These Nissan engines are awesome. Parts are tough to get.
Most likely the coolant passage is blocked with rust , crud etc.
remove the carburetor and clean the passages. Check all metal elbows for blockage . Almost guarantee it will solve the choke issue.
Hope this helps .
Hopefully DB will come back.  He has not logged on since posting.
barbender
