Dynamic Green Products Inc.
Author Topic: newest addition to my sawmill operation (pic)  (Read 2995 times)
Offline Quebecnewf
« on: June 12, 2009, 07:19:03 PM »
This is a pic of an old 3 sided planer that I am planning to set up at my mill. My hope is to use it to do some t&g board among other things.
I am planning to run it with a gas motor and I am still working on the belting hookup. I things go well I hope to have it in operation by the end of the summer.
Unit is very old but in excellent shape
Quebecnewf
Offline sprucebunny
  • Gender: Female
Re: newest addition to my sawmill operation (pic)
« Reply #1 on: June 12, 2009, 08:13:25 PM »
Thanks for the picture ! I hope you can make it work: it looks like a classic !
Offline bandmiller2
« Reply #2 on: June 13, 2009, 06:48:13 AM »
Qubec,I have an old Parks plainer that I set up with pins for a tractor three point hitch got the PTO  rpm's up by using a transmission backwards.Easy to move around when not needed and scads of power.You can plain out by the sawdust pile no mess to clean up.Frank C.
Offline StorminN
« Reply #3 on: June 13, 2009, 02:36:03 PM »
Looks great, Quebecnewf... have you figured out what motor you're going to use to power it?
Does it have square heads? Do you have any close-up pictures of the heads or knives? What shaft size are the side heads?
I've been learning a lot about these old machines lately, and I recently learned that a machine like this one - with the side heads directly opposite of each other - is called a "matcher" (as opposed to a "moulder", which is what I have, which has the side heads offset from each other). Matchers are ideal for making flooring and siding and anything that needs to match and fit perfectly t&g style or what have you... moulders are ideal for making mouldings... the offset side heads enable the two side cutters to get closer together or even overlap on the same pattern.
-Norm.
Happiness... is a sharp saw.
Offline Quebecnewf
« Reply #4 on: July 13, 2009, 05:54:30 PM »
Here is a pic of the setup I plan to use . The engine is a 8hp built back in 63 and seems to work great
i hope to move it to the mill in the coming week
Quebecnewf
Offline Jasperfield
« Reply #5 on: July 13, 2009, 09:17:04 PM »
Now you can mill antique lumber!
Offline beenthere
« Reply #6 on: July 13, 2009, 10:04:16 PM »
Looking good there. Glad to see the project coming together. I can visualize a huge pile of wood chips/shavings forming already.
Hope the 8hp engine does the trick.
Offline jimparamedic
« Reply #7 on: July 13, 2009, 10:05:00 PM »
Pretty cool let use know how it works
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #8 on: July 14, 2009, 08:26:07 AM »
Gday
Quebec thats a nice looking bit of kit it should do a good job for you Mate  ;) ;D 8) 8)
Reguards Chris
4TH Generation Timbergetter
Offline Quebecnewf
« Reply #9 on: July 17, 2009, 01:06:54 PM »
Moving the planer to the mill.
First put on kometick and wrestle into trailer
Next hoist into boston whaler and drive carefully to mill
Then use winch to haul kometick and planer ashore. Going to set it up in the shed in a few days time after I nail down a new floor.
Quebecnewf
Newest addition to my collection
Started by Radar67 on Sawmills and Milling
Last post October 06, 2005, 10:22:31 PM
by Dan_Shade
The Newest Vehicle Addition
Started by tcsmpsi on General Board
Last post September 06, 2012, 03:56:36 PM
by Delawhere Jack
Newest Addition Updated!
Last post August 14, 2012, 09:09:12 AM
by tcsmpsi
Newest Addition Dump Trailer -pics
Started by Busy Beaver Lumber on Sawmills and Milling
Last post October 04, 2010, 08:47:27 PM
by terrifictimbersllc
