Author Topic: $2 dollar tool to clean airholes on eclassic2300  (Read 2025 times)
Offline ecrane99
    • edcrane.com
« on: January 07, 2011, 06:45:19 PM »
An idea for elcassic owners:
Drill a hole through a broomstick or metal pipe and put a bolt through it.
Very simple, but effective.   A pointy bolt would be even better.
I also have a broomstick with the bolt facing forward (use a hose clamp) to clear the back 2 holes (not shown).
Ed
Offline Dean186
  • E-Classic 1400 Owner
Re: $2 dollar tool to clean airholes on eclassic2300
« Reply #1 on: January 08, 2011, 11:29:37 AM »
I like your idea ecrane.  The holes on the 1400 are slotted, but the bolt could be worked up and down.
The weld that holds the small square plate to the long rod broke on the new tool that Central Boiler provided to us. So I now have a long rod for poking out the holes in the back of the firebox.  I really liked that tool and hoping to get another one.
Offline stumper
« Reply #2 on: January 08, 2011, 12:39:25 PM »
I like the concept.  I think I'll try a combination lag screw/bolt used in furniture making.  I will try to find a double ended lag bolt to poke out the holes in back.
Offline doctorb
  • Unofficial Team Physician
« Reply #3 on: January 08, 2011, 12:49:22 PM »
I use a six foot long metal rod, with a diameter about what I think your bolt is, that's bent at 90 degrees at one end, with about 4" on the short end.  I use that end as a handle when poking through the holes at the back (using the long straight end of the rod), and flip it around to insert the short bent end in the holes on the sides.  Basically, we have created the same idea through necessity.
I thought that the new "tools" that CB sent us would perform this task, but they do not.
Offline ecrane99
    • edcrane.com
« Reply #4 on: January 09, 2011, 09:40:19 AM »
This season I am burning a free load of Pine I got from a friend.  Pine requires a bit more attention and cleaning vs the hardwood.
That is what got me thinking of a better way to clean the airholes vs putting my arms in there.
Thanks for the comments.  Ed
Ed
Offline KMAN
« Reply #5 on: January 10, 2011, 08:36:17 PM »
I took several pieces of 1/2 rebar and welded them together and then bent a L shape on the one end that is about 6 inches long. I then ground a point on the L end so if the hole is clogged some it will egg it out the rest of the way. I then use that for the side holes and when i do the back holes just switch it around and use the other end that is straight. It works amazing to clean the holes out. I too was disappointed that a better tool was not provided to clean the holes out. I also have another tool to feed in the front air hole and push it the whole back to the last hole. That is also amazing how that works when the hole gets clogged this will clean out behind the wall. That tool is a flexiable shaft from the inside of a weedeater shaft. If you have a Eclassic get a flexiable shaft from a trimmer and you will be amazed how much junk you can push out from behind the firebox. I fix mowers and trimmers so that shaft is easy for me to come across. hope that helps anybody out there.KMAN
Offline ral
« Reply #6 on: January 16, 2011, 12:30:42 PM »
I screwed in a long screw in the end of an old broom handle to clear holes in back, been working well but probably not as durable as the bolt.
Offline Flyer
« Reply #7 on: January 20, 2011, 07:32:14 PM »
Great Idea!  I've been using and old fireplace poker to clean out the holes.  Not as long of a handle though.  It can get a little toasty!!  I've got to be quick!
Flyer
Offline Tim Crowley
« Reply #8 on: January 25, 2011, 08:27:32 PM »
I just use a ski pole.  Works great.
Great tool to clean Heat Exchangers on Central Boiler
Started by Bob Lentz on Firewood and Wood Heating
Last post March 13, 2015, 05:44:11 PM
by Bob Lentz
Need a 18-20" saw, best dollar for dollar saw???
Started by Shaggy on Chainsaws
Last post September 14, 2013, 10:23:09 PM
by AdkStihl
to clean or not clean air filter
Started by kelLOGg on Sawmills and Milling
Last post December 10, 2009, 04:30:55 PM
by edwardj_
Tractor 3pt Multi-tool - And Another Log Handling Tool Added
Started by tcsmpsi on General Board
Last post February 08, 2007, 07:18:52 PM
by SPIKER
