I found a bolt on pintle ring for LT40 WM
Started by yellowrosefarm, March 23, 2013, 05:24:00 PM
yellowrosefarm
Quote from: isawlogs on March 24, 2013, 10:40:10 PM
I have hydraulic brakes on my mill, activated by the ball hook-up, so I would not be able to put a pintle hook on. I tried to go that way when I bought my mill but it was not an option, now with electric brakes it would be an easy it. I might just pull the axle off my mill and go with electric brakes on it and get a ring hook-up for it. I need to go over the brake lines and brake linings and probably drums too... might be cheaper in the long run to just go electric.
My mill had hydraulic brakes too when I first got it. That was the first thing I changed. It's all bolt on stuff and any good trailer supply can get the electric brakes as an assembly. It was less than $200 to convert. I use the mill to charge the breakaway box. It's wired so that everytime I bring the head back to the "strip" it also sends current to that little battery.
Chuck White
I'd really like to switch from the surge brakes to electric.
Only thing is, it just looks to be quite complicated to me!  :-\  :-[
yellowrosefarm
Quote from: Chuck White on March 25, 2013, 01:53:25 PM
Well, I'm probably not the best judge since it's sort of what I do for a living being a small engine/tractor mechanic who has worked on a boat load of trailers. Basically, you remove the drums, unhook or cut the hydraulic line to the wheel cylinder, unbolt the 4 bolts holding the brake assembly to the axle and remove the whole shebang. Then, bolt on the electric brake assembly, grease the bearings and put the drum back on. Some drums are made to be used either with hyd or electric, some are not, so you may have to get new drums depending. Then, there are 2 wires sticking out the back of the brake assembly. One needs to be connected to the break away switch and the red wire coming back from the trailer brake controller in the truck. The other needs to be connected to a common ground. Same for both sides. The break away battery and switch will come with instructions for wiring too. Lastly, toss the hydraulic coupler for the pintle ring and you're done. If it seems like too much, any good trailer sales/repair place can quote you a price for doing it. Should take 2-3 hours labor and the price of parts.
Dan_Shade
lots of dull bands and chains
Chuck White
Thanks Yellowrosefarm!
Appreciate the explanation, doesn't really sound all that complicated if I could just get the conversion parts.
Dan_Shade
Thanks Dan.  You guys have me in the thinking and wondering stage.  smiley_headscratch   smiley_idea
Dan's pic of the pintle makes me think of what might take place if the pintle breaks (and same ?? goes for the ball hitch as well).
The safety chains would "contain" the mill from going across the road or into the ditch, but what happens when trying to stop the loose rig? Apply the breaks and the mill slides up under the rear bumper and wipes out the hyd. controls?
Or what?
Seems an upright post (temporary or some other design) on the tongue of the mill might protect the controls.
But if the hitch never breaks loose, then no harm done.
I immediately noticed that Dan has his safety chains properly crossed and attached.  My thoughts are that for a hitch to actually fail, some sort of an accident would have to take place.
jcbrotz
Quote from: beenthere on March 30, 2013, 10:35:04 AM
Or what?
You would need to think first but hit the trailer brake controller and it will slow the trailer then the you can slow the truck and minimal damage will occur, you will/may break off the front outrigger first thing, don't ask how I know or you have to be REAL lucky like magicman was, to bad I ran my luck out years ago.
I have never really seen much difference between ball hitch and pintle you have to remember to either hitch the hitch or receiver, one or the other although the pintle is a lot stronger and a little easier to hitch.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
pnyberg
I had my LT40HD pop off the ball hitch once, about a mile from my home returning from a job 100 miles away.  The road I live on is a little bouncy.  It scared the crap out of me (not literally), but nothing happened to the mill.  I stopped without a problem.  Reattached the mill to the ball, and finished the ride home.
The next day, I tightened up the nut inside the hitch to remove some of the slack.  No problems since.
So, I'm confident the chains will work as they should (at least at 30 mph).  I have no confidence that the trailer's safety brake will work. Maybe I will inadvertently test that someday.
--Peter
No longer milling
hamish
Pintle hitches take the guess work out of whether or not you have made a secure attachment, if the throat is closed its secure.
It is the most secure attachment for a trailer out there, and much more user friendly than a ball hitch.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Dan_Shade
loosing a trailer is a fear of mine.
I saw a small trailer come off of a vehicle once on I-81 years ago, luckily, it veered right and went off to the side of the road.
One of my concerns has been the hitch coming off of the truck.
At any rate, I like my setup, it's easy to remove the ring, and it's easy to hook up.  I normally sit on the ring when I'm turning logs, it's suprisingly comfortable!
barbender
 I'm fine with my ball hitch, but I would like to get a couple of hitch pins to replace the bolts that attach the hitch assembly to the mill frame. When I am set up and milling, the hitch and my shins want to occupy the same space at times ::)
pnyberg
I just checked, and found that the hitch on my mill is welded on, not bolted.
--Peter
No longer milling
Thomas Ruga
Guys: Safety chains are most necessary. I had one of the guys hook up my work trailer last week in the rain. I didnt check it. At 55mph and a wicked bridge the trailer came off the top of the 2 5/16 ball. The emercgency wire pulled out and the brakes applied and slowed the truck to a stop. The trailer never came close to the truck. After a prayer and hooking things up I went another 150 miles no problems. Use your safety stuff, it works.
Grey haired and safe,
Ga Mtn Man
Thomas Ruga
Paul: Yes. slowed it to a stop! We adjust the electric brakes on all of our trailers every 4-6 months. With a good e-brake controller you can tell if the e-brakes are getting tired. We put a priority on brake maintenance on all of our fleet trailers. 80,000 lbs is a lot to stop! Maintenance is a lot cheaper than paperwork for an accident report and etc...
Ga Mtn Man
If my trailer came unhitched and the :) emergency wire pulled, the electric brakes would slow the trailer to a stop.  Things must work differently up in New Jersey.
If the two were still attached via the safety chain, the trailer would also slow the truck to a stop, unless I'm missing something here.  ;D  That all is depending on the WM trailer having its own brakes.
Do they normally have trailer brakes? Maybe required by law due to weight?  Seems it would be the wise idea.
Tom the Sawyer
Thomas R.,
Reply #40 - ".... 2 5/16 ball"
Reply #42 - ".... 80,000 lbs. is a lot to stop"
Are you referring to 2 different set ups?   :-\
Before I retired I worked several fatality crashes caused by runaway trailers, both ball hitch and pintle hitch style trailers.  In those cases the safety chains had not been connected and the breakaway box it was either defective or it wasn't hooked up either.   smiley_thumbsdown
There are no bumpers or crash collapse zones on trailers, it doesn't have to be a large trailer to be a hazard if it gets loose.  The hitch is like a spear piercing the windshield or side of a vehicle.  Keep your trailers in good repair, especially brakes, tires and wiring.  Connect the safety chains, hitch pins and the breakaway wire if you have one.  Secure your load and take the time to set the trailer brake sensitivity, you'll never know when you will need it.
Our families are on the road with those trailers, be safe.  smiley_thumbsup
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Ga Mtn Man
Quote from: beenthere on March 31, 2013, 11:40:19 PM
OK, now I get it.  I forgot about the chains tying the truck to the trailer. :-[
Thomas Ruga
Tom The sawyer: Yes 2 different trailers. All of our smaller trailers have electric brakes and safety chains.
They typically haul up to six tons. The larger trailers 40' and longer have air and haul anywhere from 10-100 tons. Sorry for the confusion...
kderby
Thomas, Thanks for your post:
Quote from: Thomas Ruga on March 31, 2013, 10:47:43 PM
I would like to learn how to adjust my e-brakes.  The gain mechanism on my dump trailer seems to be less effective.  Do I tighten the brakes or adjust another part of the system?
Kderby
Thomas Ruga
derby: You can try adjusting the brakes with the adjusting screw/knob/thingy that turns. We also have upgraded our controllers to electronic. You can adjust the brakes to any conditions or load that you are hauling. Here in NJ you can even adjust them to the dumb drivers on the road!lol ;D
