Author Topic: Lucas saw mill blades  (Read 1174 times)
Offline Peder McElroy
  • New LT 35 and 6 Grandkids , What could be better
« on: May 11, 2014, 12:49:40 AM »
I have had my saw blades re tipped in the past , but they don't seam to be as good as the originals .Today I had two blades lose two carbide tips each in two logs and the logs were Redwood with no rocks/dirt or metal. The cost of new blades is so high , any ideas.
Offline Ianab
Re: Lucas saw mill blades
« Reply #1 on: May 11, 2014, 01:37:04 AM »
Find a better saw doc?
I mean the tips are simply brazed on to the blade when it's initially made. Replacement tips can be brazed on in pretty much the same manner, and should be comparable quality?
But poor quality "weld" or the wrong grade of carbide will give you grief. Have a look at the failures, has the join failed, or has the carbide shattered, leaving some of the cutter still attached? That gives you a place to start.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #2 on: May 11, 2014, 06:44:46 AM »
http://www.forestryforum.com/board/index.php/topic,74143.msg1123157.html#msg1123157
let them do a Saw Doctor visit with those tired blades.
Best
DGDrls
Offline thecfarm
« Reply #3 on: May 11, 2014, 07:50:21 AM »
Call the place you did them. They SHOULD go good on them,if it has not been too long. Some places want you as a customer and some just don't care.
Offline tjhammer
« Reply #4 on: May 11, 2014, 03:29:01 PM »
as Ian said you should try a different saw doc , have you ever had your saw tension checked that could be one reason the saw don't saw as well when returned from the doc as far as the tips falling off if they were installed right the carbide should break  before falling off I have hit metal and broke off 4 tips but the weld was fine
tj
hammer
Offline sigidi
« Reply #5 on: May 11, 2014, 04:22:55 PM »
As the other lads have mentioned Peder - check the teeth, if they have shattered - hit something, then TCT will be left attached to solder,if no TCT left and only solder in the pocket, then the teeth have let go - bad soldering from saw doctor. If the saw doctor comes good on fixing them, give him another chance, if not move on to another saw doctor.
I've been through 8 sawdoctors
Offline treeworkx
« Reply #6 on: May 11, 2014, 07:49:56 PM »
Gidday Peder,
I've had some done by acme saw in San Jose.
Nev
Offline leroy in kansas
  • Don't squat with your spurs on.
« Reply #7 on: May 12, 2014, 11:27:10 PM »
There's a thread here somewhere on doing your own replacement teeth. Didn't look to be rocket science. Maybe a bit more like brain surgery.   :D
« Reply #8 on: May 14, 2014, 11:27:40 PM »
Two new saw blades over-nite from Left Coast Supply and I'm back at it. Sent the old ones to Bill Dooley in Portland to be re tipped (New Saw Doc  too me ) Happy
Lucas Mill blades
Started by BuckShott on Sawmills and Milling
Last post November 08, 2019, 09:50:39 PM
by Don P
Saw doctor in Oregon for 827 lucas mill blades
Started by boardwalker on Sawmills and Milling
Last post January 29, 2017, 11:00:38 PM
by TKehl
Peterson Blades, vs Lucas Blades
Started by Nate Surveyor on Sawmills and Milling
Last post May 07, 2007, 12:26:56 AM
by Firebass
lucas blades
Started by clairmont on Sawmills and Milling
Last post December 19, 2013, 05:08:44 PM
by sigidi
