Author Topic: A new learning  (Read 659 times)
Offline whittle1
A new learning
« on: May 29, 2016, 09:48:02 AM »
Quarter sawing a large pin oak about 22" the first one beautiful quarter sawn lumber but it did seem like I  was
going slower and slower as I went. Started on the 2nd one about the same size and the saw was really struggling with a thru cut. Rolled the top cant off and the next board the saw was snaking real bad, put on a new blade and started with the 3rd cut about 19" across and saw carriage travel was extremely slow and completely stopped about 6" from the end of a 10' long log. Thinking it was a problem with the belt or motor on the carriage I tried to push the saw the rest of the way, OOPS blade came off. Now I'm looking at this big pile of pin oak and white oak logs and thinking I will never get these all cut up.
Thank goodness for Woodmizer Techs after a quick description of the problem he suggested I check the belt tension. Tensioned the belt and back to cutting like new. When rebuilding the saw I had originally set the belt tension using a gates belt tension gauge to 10lbs force for 7/16 deflection. It was still about the same which I guess was ok for the pine I had been cutting. Now I'm closer to 20Lbs which feels about right if not using a gauge and just tensioning by feel.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: A new learning
« Reply #1 on: May 29, 2016, 10:04:40 AM »
Whittle1,
   Can you update your profile with your equipment details so we can see what kind of mill you are talking about. My mill specs call for 14 lbs at 7/16" deflection if I remember correctly. I check it regularly but fortunately have not had to adjust it yet.
    Thanks for posting.
Offline whittle1
Re: A new learning
« Reply #2 on: May 29, 2016, 10:29:28 AM »
1994 LT40 the book calls for 7/16 deflection at 5lbs. I'm running a powerband and can only assume this was a measurement for 2 single belts. So 10 lbs should have been by the book.
Learning as I go
Started by 123maxbars on Sawmills and Milling
Last post October 24, 2012, 11:49:53 PM
by WDH
We're learning
Started by Ed_K on Sawmills and Milling
Last post July 20, 2003, 06:43:35 PM
by Ed_K
Learning on the job
Started by Will.K on Timber Framing/Log construction
Last post February 07, 2021, 12:47:51 PM
by Will.K
Learning....
Started by OlJarhead on Sawmills and Milling
Last post April 13, 2016, 05:24:22 PM
by Magicman
