BLUECREEPER Poster Award #4!
Drive sprocket size is a major factor here, but the end result also depends on exactly which chain models are involved
Quote from: SawTroll on May 29, 2015, 10:50:56 AMDrive sprocket size is a major factor here, but the end result also depends on exactly which chain models are involvedI understand that completely, with all things being equal are the 3/8LP the easiest to pull? (excluding 1/4 of course).
Now I'll make things really confusing Here's another low profile 3/8" chain......the Oregon 76LG. Introduced in 1976 and discontined about 20 years later.An actual true 3/8 pitch chassis to match a full size 3/8 sprocket.Cutter bits are equivalent in size to a .325 and chisel to boot.Top picture....76LGMiddle picture ...old timbersport race chain trick. Full size cutter on lightweight 76LG chassis. Bottom picture.....Stihl 33Topic Super 3/8" low profile chain compared to full size Stihl 33Rapid Super 3/8"chain.
I understood 100% of all of that.
Now I'll make things really confusing Here's another low profile 3/8" chain......the Oregon 76LG. Introduced in 1976 and discontined about 20 years later.An actual true 3/8 pitch chassis to match a full size 3/8 sprocket.Cutter bits are equivalent in size to a .325 and chisel to boot.Top picture....76LGMiddle picture ...old timbersport race chain trick. Full size cutter on lightweight 76LG chassis. Bottom picture.....Stihl 33Topic Super 3/8" low profile chain compared to full size Stihl 33Rapid Super 3/8"chain. (Image hidden from quote, click to view.) (Image hidden from quote, click to view.) (Image hidden from quote, click to view.)
Basically true, but there are no such thing as true 3/8" chain, as the pitch basically are .366 on both regular and lo-pro, and not .375.
Started by ET on General Board
Started by Shagy on Firewood and Wood Heating
Started by stavebuyer on Sawmills and Milling
Started by LeeB on Health and Safety
